Sound system upgrades
Old Sep 27, 2007 | 09:11 AM
Originally Posted by 707coupe
I went with 2 10 inch jl w3 with jl 1400 amp good setup gives me just enough deep bass that the system just didnt have before. yes its the preamp i believe had my shop do it took a hour to do i had everything done already myself they just had to take dash apart and run remote which i wasnt in mood to do plus drill the power wire through the firewall never a fun thing but thats all they had to do
PICTURES! Where did you locate the 10's? The amp? How does it sound? PM me please, I'd like to get some details.
Old Sep 27, 2007 | 09:27 AM
ghideon's Avatar
ghideon
More info please, and spell it out cause I'm an idiot when it comes to these things. I'm very interested in adding something for a lil more bass. Or, a lot more.
Old Sep 27, 2007 | 12:45 PM
707coupe's Avatar
707coupe
ill take pics when i gt back to the house basically i had the box i got of ebay that was fitted for the g35 installed in the rear matching carpet perfect fit in the odd shaped opening in the trunk the amp is mounted on the rear of the box. Had to use a lne out convertor which basically converts the speaker signal to a preout signal to send to the amp pretty simple addition 4 wires max then ran the remote to the rear of the deck and that was all. pretty much a basic setup
Old Sep 27, 2007 | 05:45 PM
tjlskyline's Avatar
tjlskyline
707 you have any pix of the final set up?
Old Oct 5, 2007 | 04:36 PM
marsb007's Avatar
marsb007
has anyone managed to replace the stock speakers in the doors? I'm sure the Bose ones suck... and simply replacing them would give a clearer sound without adding on anything. Any thoughts?
Old Oct 5, 2007 | 08:57 PM
In fairness I haven't given the system a really good critical listen. On my 2 test drives I turned the stereo off most of the time to listen to the engine and exhaust. But form the research I have done over the internet and after asking people with more experience than I have, I've come to the conclusion to give it a fair shake before dismantling my car and dropping major coin for custom work. What I'm finding is that the informed opinion of many is that the system sounds pretty damn good but only lacks powerful low bass response. That problem is a pretty easy and relatively inexpensive fix by adding a quality amplifier and a good subwoofer. I'm thinking that I'll get a custom sub enclosure (possibly 2) and a 10" with adequate power (maybe 600 watts) and see if that takes it low and loud enough for my tastes.
Old Oct 7, 2007 | 11:23 PM
UNV-IT46's Avatar
UNV-IT46
I have a JL W7 10" sub with a JL 500/1 amp for it. I need to have it installed. thats all i will be doing as far as the sound system is concerned. the rest of the system sounds great to me. just needs a little more bump
Old Oct 8, 2007 | 11:12 AM
tjlskyline's Avatar
tjlskyline
I put pix of my install in the mods post. Sounds real nice with just one 12 in the trunk. Although I lost some of the little trunkspace I had.
Old Oct 21, 2007 | 12:19 PM
fcarpio's Avatar
fcarpio
I'm considering DLS Iridium 8.3 for the front stage. 8" to replace that stock front door 10"s, 3" mids & 1" tweeters in stock locations. I'll have to see about the rear because I'm sure it will be an installation nightmare with depth restrictions. Most likely no rear fill and a pair of 10"s in the trunk or rear deck.
Good choice, I am also considering the DLS. I have the amps (A4 and A6) and I love them.
The best inteface to the factory Bose I have found so far is the AudioControl DQL-8, check it out. A cheaper option is the AudioControl LC-8.
Old Nov 3, 2007 | 04:14 AM
707coupe's Avatar
707coupe
Old Nov 3, 2007 | 10:24 PM
707 which LOC did you choose?
Old Nov 3, 2007 | 11:37 PM
707coupe's Avatar
707coupe
i ran a stinger Loc with jl wiring kit
Old Nov 6, 2007 | 01:47 PM
fcarpio's Avatar
fcarpio
Agree. I am looking at the same set of speakers. I have an Audiocontrol DQL-8 digital signal processor that will interface directly with the stock head unit, one DLS A6 mono and a second DLS A4 four channel, and a pair of JL W6 10" waiting in to be installed. All this stuff came out of my G35. BTW, the Z-Enclosures for the G35 fit beautifully in the G37. I will send pictures when I am done. I got tuition coming up and it is going to be murder so it may be a while...
Old Nov 6, 2007 | 01:50 PM
  #29
fcarpio's Avatar
fcarpio
Originally Posted by colds14
You will most likely have to add in something like JL's cleansweep, Alpine's Imprint processor, or the Rockford three-sixty. I'd be willing to put money on the factory amp having crossovers built in sending independent signals to each speaker. My girl just picked up her new G today and Hopefully I will be able to steal it for a day to take it apart and see whats going on.
Nah, Audiocontrol DQL-8 is the best by far, check it out at audiocontrol.com.
As for the radio....If you got the Bose then you have a great sounding source to use with what I mentioned above. If its none Bose then you will have to deal with using what radio/cd came with the car. The dash itself is the biggest problem and I have yet to find any pics of a JDM dash thats got a standard opening like the first gens.
Agree, the stock radio sounds pretty good. I like the fact that it has a Burr Brown DSP inside.
Old Nov 6, 2007 | 01:52 PM
  #30
fcarpio's Avatar
fcarpio
On my G35 I chucked the spare tire, that is what road side assistance is for. I intend to do the same in my G37.
