Help Confirm offsets before I order...
I'm about to order new wheels, but I just want to confirm the offsets before I pull the trigger. My car is a 2012 G coupe. Lowered on Eibach Pro-Kit springs. Tires are 245/35/20 up front and 275/30/20 in the back (I'm probably going to a 285 in the back when these wear out). I want a flush stance...NO poke/stretch and I'm not running a lot of negative camber. I'm planning on ordering 20x8.5 +25 up front and 20x10 +30 in the back. I'm set on the sizes, but do those offsets sound right for the flush look that I'm going for?
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
Dr.Pat (09-01-2014)
You can go even +20 fronts with those tyre size and rim width.
im running 20x10.5 +30 with 285mm tires and -1.8 camber and toe in spec.
ck1109
10-15-2015 11:06 PM
Kojack
10-09-2015 05:53 PM
