Official~Best offsets for running FAT tires!
#1156
It is possible but not really Recommended. You will need +45 10.5 up front and the +25 10.5 rears and a good stretch and negative camber up front. Keep in mind the Black G37 with graphite CV3s 10.5 all around on our site was on bags. I myself have debated on this but for my type of driving I just look past this option, but is very sick and great for photoshoots and shows not for a Daily Driver though at least I wouldn't recommend it.
#1157
My camber is -0.4 in front and if I was running -2.0 degrees camber, and independently wealthy, I'd run a higher offset.
#1158
Check this thread, the first couple pages, Tbulsara & MylilG are running 10.5+35 square sets, you might have inner clearance issues in front at the steering knuckle w/ the +42, which could be solved w/ a small spacer if you don't run too much tire.
https://www.myg37.com/forums/brakes-...post-here.html
#1159
Yes, you can make anything work... poke-stretch-camber-spacers... depends on the look you want and the functionality. I posted the coupe as a reference from a wheel guy, but should mention, they can generally speaking fit wider wheels with more aggressive ET
#1160
Here yah go sorry for the late reply ! I ended putting 265/40 18 in the front as well hmm.. I'll say if you don't care about scraping or being low it's perfectly fine. But for me I want something that sat higher looking flush so I decided to go 19. Yet tire sizes were a lot cheaper for 18 and lighter!!
#1161
What do you guys think of Work Emotion D9R's on
19 X 9.5 + 23 255/35/19
19 x 10.5 + 23 275/35/10
Going to lowered on Tein Flex Z coilovers, should i run + 30 instead in the rear?
#1162
Here's a 10.5 +25 on 275s, IMO it's pretty tight, that extra 5mm with the +30 will come in handy.
https://www.myg37.com/forums/brakes-...ml#post3891573
#1164
That +23 will lock you in, and may be too much, I'd run the +30 w/ the 275/35, and in front I'd run a 255/40 vs. the 255/35, unless you're really wanting that smaller sidewall up there.
Front: 19x9.5 +30 (255/35/19 Cause I still have a pair of 7.5/32 PSS)
Rear 19x10.5 +30 (275/35/19)
Thanks for the pic, that 5MM looks like it would make it almost perfect...
The front would poke or rear? Im going for around a one finger gap drop, i have SPC front upper control arms and rear camber arms as well.. gonna order Tein after car fund gets replenished...
#1165
So just to confirm (about to order the wheels),
Coupe or sedan? 1 finger gap with a 275 and a 10.5 + 30 is going to poke on a sedan. Look at my post history, I posted a pic with a 275/35/19 on 10 + 30. There is pretty much no finger gap. It pokes slightly, and I had a good amount of negative camber.
#1166
Coupe and planning to keep it at -2 camber in the rear...
#1167
Here's another, just pay attention to the wheel rather than the tire, it's 10.5 +27, so you'd have 3mm inside from that, still some poke when looking down the side but probably no more than 5mm from the looks of it.
reNeglect (01-30-2017)
#1168
#1169
If you want a similar fit, the 9.5 +23 and 10.5 +30 will be much closer, the rear wheel will be about 6mm further out, if you run a 5mm spacer on a +30 you'll only gain 2mm, not really worth the hassle of running a spacer IMO. You want a bit less aggressive in front since the fender isn't flat-rolled in front but is in back. Should be happy with the 9.5+23 front 10.5+30 back, assuming you ARE wanting a very flush fit.
#1170
