2010 G37s Camshaft Issue
Old 08-19-2015, 05:32 PM
moy92
moy92's Avatar
Bare with me, Im new to this. I recently purchased a 2010 G37s with 92k on it. It had the Engine light, VDC, and traction control light on. After getting the diagnostic report, the car was showing a P0340 code (camshaft sensor). So i changed both bank 1 and 2 camshaft sensors. Since changing the sensors, the car will now not start unless I unplug the block 1 camshaft sensor, and will be on limp mode where it does not go over 3500 RPM. I was wondering if anyone had any idea what the problem could be or has had similar issues? if so, can you point me at the right direction as to why the car is still in limp mode, why it is still showing a problem with the camshaft and what I have to do to get it fixed?
Thank You
Old 08-20-2015, 08:43 PM
si_driver
si_driver's Avatar
Did you replace these with OEM Nissan sensors or Autozone or alike?
I have similar issues on my 2003 G35 a while back and when I replaced them with OEM sensor, the problem went away.
GXXXVII
General Tech Questions
12-11-2021 08:58 AM
Thedbarz
33
02-09-2016 12:05 AM
maybeg37
09-08-2015 02:33 PM
regimelife
08-18-2015 04:46 PM
pcwd
08-12-2015 06:54 PM
Quick Reply: 2010 G37s Camshaft Issue
