Need help!! Diy turn as tail diode dynamics
#46
Finally got it installed. Took longer than expected because of my crappy wire stripper, and I had to re-wire the resistors I already had but man is it worth it. Looks amazing.
Side note: There was so much gross crap I cleaned off the back of the tail lights. It looked like they were never removed in 8 years.
#47
#51
Does anyone know if the plug and play kits are available for the sedan yet? If not, I might just pull the trigger for the DIY kit.
Also curious if anyone that's installed this is using the factory rear turn signal bulb/location for anything else anymore (i.e parking lights)?
#52
They've been trying to get the plugs in since early in the year. Pull the trigger, you won't regret it
I left the factory bulb in disconnected.
#53
The connectors for the Sedans have been quite difficult to find, but our development team is working on it
Thanks!
Nick C.
Diode Dynamics (08-10-2015)
#58
#60
Ordered the DD tail as turn on Monday and got it today. Thanks Nick!
I ended up installing them directly to the taillights. Here are some pictures of the wires cut and the resistor to stop hyperblink.
Diode Dynamics Tail as Turn Infiniti G35/G37 Sedan - YouTube
