Negative Camber
Negative Camber
Hi all.
I'm trying to reach out to the stance guys who are running negative camber on their coupes.
I'm maxed -5 rn all around with all stock arms dropped on Fortune Auto 500 series coilovers; with that being said, I know I can get camber arms and get more, but I just wanted to see if anyone is running more than -5 degrees of camber on OEM-Style coilovers in the rear, and if so how much and how did you correct your toe ?
Thank you in advanced.
I ran some mild camber on my older car, and -5 is pretty ridiculous..Not to sound like a tool or anything, but you may want to consider running a different setup if you need that much on static.
Also, toe should ALWAYS be at 0. That is the most important thing for lowered cars. If not, your tires literally scrub across the pavement. That will kill your tires quicker than camber ever can.
Geesh .... why do people think this looks good? I prefer the whole width of the tire on the road. You are missing the blue led under carriage lights.
I’m running broadway static 32k front 30k rear swift springs. I was at -5 rear and -4 front on stock everything
currently go
t new wheels, going mega camber, bucket delete , traction arm, rear upper.
And also front upper to fit these wheels correctly.
They are 19’s. 10.5/11.5 +10 4/4.5 lips on 235/40 245/40
super wide in the back so that’s why I’ll be grabbing a rear upper arm to get around -11
currently go
SOLISIMO
Picture Share G Coupe
60
07-16-2009 07:37 PM
