Sponsored By:
Sponsored By:
switch to Mobil1 now?
Old 01-19-2012, 08:24 PM
G37SBS
G37SBS's Avatar
i have 08 G37s 50k miles and i been using dealer for an oil changes. Now i want to switch to Mobil1 Synthetic oil. So i want to know is it gonna mess-up my engine since i been using dealer oil for 50k miles already..
Thanks
Old 01-19-2012, 09:19 PM
apexi350z
apexi350z's Avatar
You can switch after the initial break-in period. Probably after 2 initial oil changes. You are fine with Mobile One or any synthetic oil now. Make sure to get a good filter, that's what matter the most.
Old 01-21-2012, 02:50 AM
hustlerj
hustlerj's Avatar
its completely up to you. some people changed to synthetic oil at 0, and some people changed it when its 2.5k. i'm going to change it on my next oil change, which is 7.5k
Old 01-21-2012, 08:18 AM
SwissCheeseHead
SwissCheeseHead's Avatar
I changed to Mobil 1 at about 44K miles also on dealership oil previous. (I bought it used with 43K miles) Everything runs perfectly.
Old 01-21-2012, 09:11 AM
Coprolite
Coprolite's Avatar
Your G will thank you for it.
Make sure to check your oil on a regular basis. Some people have seen consumption when just changing brands. I doubt this would happen to you, but it isn't a sign of the apocalypse, either.
Old 01-21-2012, 09:31 AM
xtremeroller
xtremeroller's Avatar
I changed mine to mobile1 at around 27k miles. No issues here at all.
Old 02-01-2012, 01:04 PM
LexiG37
LexiG37's Avatar
Up to 22k my G ran on conventional dealer oil, then at 22k it got Syntec, now at 26k it got Mobil1. Runs great!
Old 02-01-2012, 01:16 PM
j23a45m
j23a45m's Avatar
I've been on Synthetic as soon as I hit 10K, no issues here.
Old 02-01-2012, 01:50 PM
datboiroy
datboiroy's Avatar
I've been on Mobile 1 since around 30k and no problems.
Old 02-01-2012, 01:54 PM
pauliewalnutzz
pauliewalnutzz's Avatar
I changed to mobil 1 at 12k miles, running beautifully
Old 02-01-2012, 02:13 PM
TSG37
TSG37's Avatar
is it really worth changing it?
Old 02-01-2012, 02:17 PM
pauliewalnutzz
Most definitely worth it.
Old 02-02-2012, 03:48 PM
lier200a
lier200a's Avatar
My dealer only uses Mobil1.... I thought it had to be synthetic oil anyways.
Old 02-02-2012, 06:00 PM
MParker
MParker's Avatar
I went to a synthetic 5w30 blend after the first oil change. I change the filter every time.
Old 02-02-2012, 08:42 PM
SleepyMonkey
SleepyMonkey's Avatar
bought mine used with 20k and have been putting synthetic in it since. It uses a little oil, but so did my 3.5 Altima
Quick Reply: switch to Mobil1 now?
