Maintenance other light center dash
I just bought an 08 G37 coupe used.Coming out of an 03 G35 sedan. In the center of the speedo & Tach there is a msg center, when you start the car it always starts out on "Maintenance Other" and if you want anything else you have to change it manually by hitting the toggle on upper right hand of dash. I just changed the oil and filter. I have searched the forum with no luck on finding the way to reset light.
What is the correct way to reset this ?
Cdng37 Your talking about the 2 buttons that toggle through the displays [temp,MPG,time& mileage] correct? Do you just hold these down for a set time? And should you have to toggle it say to temp each time you start car or should it come back to where you left it from when you shut off previously?
Thats what I kinda thought it should do,,But I dont think its working correctly. I have to get back to the dealer that sold me the car and pick up the owners manual and make sure there is not something wrong. Thanks for the help
stealth210
General Tech Questions
27
07-26-2017 06:48 PM
bingpwr
09-04-2015 09:44 PM
