List of ITBs for verts- FYI ONLY
The following ITBs are for your information only - may not be applicable to your vert.
ITB
Number Date Title
11-003 01/14/2011 Navigation System - Map Data Update Matrix
10-023A 01/06/2011 TPMS/Keyless Systems - Signal TECH II Diagnostic Tool
10-074 12/15/2010 ABS/TCS - CAN Diagnostic Information
10-071 11/12/2010 Interior - Rattle Noise From Rear Headliner Area
10-070 11/11/2010 Body - Convertible Top Water Leak At Windshield Header
10-069 11/05/2010 Body/Interior - Convertible Top Headliner Service Info.
09-012B 11/03/2010 Emissions - EVAP System DTC Diagnostics
10-067 10/21/2010 Steering/Suspension - Wheel Bearing Collision Damage
10-011A 10/19/2010 Body - Door Accent Garnish Replacement
09-050A 09/30/2010 Tire Monitor System - Warning Lamp Diagnostics
10-059 09/10/2010 Antitheft System - NATS Security VBC Logic
10-010C 09/07/2010 Engine Controls - Low Battery Voltage/No Start
10-056 08/24/2010 ABS/TCS - Wheel Speed Sensor Diagnostics
10-048 07/30/2010 Engine - Oil Level Is Too Low/Unusual Engine Noises
10-044 07/09/2010 Body - Convertible Top/Trunk CONSULT III Work Support
10-027A 06/29/2010 Lighting - Xenon Headlamp Service Info.
10-038 06/21/2010 Engine Controls - ECM Programming Interruption Recovery
10-039 06/21/2010 Electrical - MIL ON/DTC P0128 Due To Remote Start Sys.
09-029A 05/14/2010 Cooling System - Long Life Coolant Information
10-029 05/07/2010 Computers/Control - CAN Code, Diagnostic Tips/Guidelines
10-021 03/11/2010 Electrical - JIS/CCA Battery Testing Information
99-037P 03/11/2010 Electrical - Battery/Starting/Charging Sys. Testing
10-006A 02/11/2010 A/T - 5 Speed A/T DTC Diagnostics
10-004A 01/26/2010 A/T, Interior - A/T Vinyl Shifter Boot Comes Loose
10-012 01/21/2010 A/T - 7 Speed A/T, Fluid Level Checking/Filling
10-008 01/19/2010 Engine Controls - Seized O2 Sensor Removal Procedure
10-005 01/12/2010 Engine - Drive Belt Noise Diagnostics
03-051E 01/04/2010 Lighting - Exterior Lamp Fogging Inspection
08-021B 12/11/2009 Navigation System - HDD Navigation Map Data Updating
09-067 12/08/2009 Engine - Reman Engine Start Up Lubrication Information
09-066 12/03/2009 Body - Power Window Switch/Window Regulator Replacement
09-063 11/18/2009 Vehicle - VIN Plate/Certification Label Replacement
09-062 11/17/2009 Emissions - EVAP Canister Vent Control Valve Replacement
09-059 10/28/2009 Keyless Systems - Intelligent Key(R) Battery Replacement
08-015A 10/16/2009 Tires - Tire Pressure Information
ITB
Number Date Title
Most applicable ITBs for vert from owner interests are :
2mnycars (09-01-2016)
I gave them permission to be first and to use my car for the solution.
This may have been the one they used my car to get the prototype for. I was told because of a fix engineering did on my car (took like 3 weeks to wait for the engineer and get a working prototype with testing), it eventually became a ITB...
My car has been the lab rat on too many times. Usually, the hold up is waiting for engineering to make their way to your dealer. Even when they are traveling through, they may have to come back to complete the analysis and come up with a solution. It can take 1 to 3 weeks before you see your car back if you are the guinea pig per incident. My car is quiet again and I'm hoping I'm done with engineering for a long time.
Folllowing ITBs have been updated: FYI:
10-076A 04/26/2011 Engine Controls - MIL ON/DTC P1421 Stored
10-075A 04/14/2011 A/T Controls - Shift Issues/Multiple DTC's Set
09-012C 04/06/2011 Emissions - EVAP DTC Leak Diagnostics
04-021C 04/06/2011 Steering/Suspension - Wheel Alignment Info.
08-046C 04/05/2011 Steering/Tires - Pull/Drift/Steering Wheel Off-Center
11-022 03/21/2011 Tires - Mounting Information/Precautions
99-043F 02/11/2011 Paint - Paint Swells/Discolored Under Paint Guard Film
08-015B 01/25/2011 Tire Monitor System - Tire Pressure Information
