Difference between "D" and "DS" with paddleshifters?
Old 03-10-2011, 11:45 AM
SaMaster14
SaMaster14's Avatar
Well, I never thought that you could use the paddleshifters on the G in normal "D" drive mode (I thought they could only be used when in "DS" sport mode). But I was driving along today and put the car into D, and unknowingly (just on impulse and muscle memory) started using the paddles. When I parked, I noticed that I was still in normal Drive and found it surprising that I was able to use the paddles.
I was just wondering if there was any difference at all when using the paddles in D mode instead of DS mode (I was only driving a couple of blocks so I didn't really notice a driving difference...) Does it change the way the car drives at all?
Thanks (and sorry if this is a really stupid question...)
Old 03-10-2011, 11:51 AM
TheIvoryG
TheIvoryG's Avatar
You can change gears in either mode. But when in D, the tranny will ultimately go back to D when the revs settle. When in DS and you change gears, it will stay in manual mode and not go back to DS.
Old 03-10-2011, 12:29 PM
MACS
MACS's Avatar
^^^He's right. In Drive you can still use them, but if you down shift to 5th, and then leave it alone, it will go back to auto and shift you to 6th and 7th. (at cruising speeds I notice that one touch of the downshift paddle puts you in 5th)
If you are in drive-sport and downshift... it will stay in that gear until YOU do something. I imagine there is a failsafe, though I won't test that theory.
Old 03-10-2011, 01:12 PM
SaMaster14
SaMaster14's Avatar
Oh interesting. Thanks for the replies!
And isn't there a rev limiter that doesn't allow you to truly redline the car?
Old 03-10-2011, 01:20 PM
JohnEnglish
JohnEnglish's Avatar
You can redline the car but you can't blow the engine.
All this and more can be found in the manual.
Old 03-10-2011, 01:26 PM
soolman32
soolman32's Avatar
Sums it up.
Old 03-10-2011, 05:29 PM
bitNine
bitNine's Avatar
Also, when in D, you can pull and hold the + paddle to return to auto mode.
In DS auto mode, it will rev-match down shifts. Except I've never seen it rev match 2-1 when coming to a stop.
Old 04-22-2014, 01:33 PM
Muujig612
Muujig612's Avatar
will u gain more acceleration power in DS mode? Would there be any difference in 0-60 time?
Old 04-22-2014, 08:16 PM
MalbecG37S
MalbecG37S's Avatar
No - none at all.
If measuring 0-60, I assume you would be at WOT. At that point, the acceleration should be identical.
stm37s
The M - Spot
14
10-23-2015 01:56 AM
ck1109
10-15-2015 11:06 PM
rk325
10-13-2015 01:51 PM
Bennyjoel
09-30-2015 11:56 PM
si_driver
ECU Tuning / Dyno Data
24
09-29-2015 11:38 AM
Quick Reply: Difference between "D" and "DS" with paddleshifters?
