DIY: Traction Control Switch (Really Shut Off Traction Control)
Old 02-19-2016, 03:45 PM
  #46
Gregor12
Gregor12's Avatar
Originally Posted by Lt8Che
I was thinking about doing the same. Someone did a write up on this on the 370 forum a while back but I cannot find it now.
Yea same here lol. Really grinds my gears. Im just going to buy a fuse tap and have it wired through a switch with an inline fuse.
Old 02-20-2016, 02:57 PM
  #47
Lt8Che
'Cuz Racemod-erator
Lt8Che's Avatar
Just bought a momentary switch and gonna attempt this when it gets in as well as relocate some of my other switches.
Old 02-20-2016, 10:31 PM
  #48
Gregor12
Gregor12's Avatar
Lol sweet. You get to be the Guinea pig then haha I had another idea though. What if you bought a toggle switch though? For example, one way would cut the power of the brake lights, but light up a small 12 volt light. That way you always know what's on and what's off haha. I'm paranoid about hitting it and forgetting which way is on and off lol
Old 02-21-2016, 06:21 PM
  #49
Jonesmeister11
Jonesmeister11's Avatar
Lt8Che, consider to editing your first post and put this guide for removing the center console, of course to help people out!. It's the best guide I have found. http://www.twmperformance.com/manual...ion_manual.pdf I think I now know why you were able to get to yours easily. We have different center consoles, where the 12v, and usb go. Mine is one solid box, looks like yours comes apart?
Oh and the tools I used were, trim removal tools, phillips head screwdriver, needle nose pliers, a soldering iron (for a source of heat only, I did NOT solder the wires just wrapped them around each other and slid heat shrink on), heat shrink, extra wire (I used about 3 feet [rough guess, but it had a just enough slack for my liking]), razor blade (to remove the black thin plastic film wrapped around the wires and to shave the insulation from the wire we are cutting [its really really thin]), and a simple wire cutter to cut the wire! I think that was it!
Old 02-22-2016, 12:13 PM
  #50
Lt8Che
'Cuz Racemod-erator
Lt8Che's Avatar
That's why I think I'll just do the momentary switch, so I can hold it on and when I release it's a closed circuit again.
Pretty good PDF, I'll add that in. It looks like different year models are slightly different. Thank you for the additional info!
Old 02-22-2016, 02:49 PM
  #51
Gregor12
Gregor12's Avatar
Yea I agree. Probably going to do the same
Old 02-22-2016, 03:10 PM
  #52
Jonesmeister11
Oh and I have a 2011 S. Not sure if that matters.
Bosch module off
T/C and module off.
Old 02-22-2016, 04:04 PM
  #53
lobuzz311
lobuzz311's Avatar
Thanks for that ^
It will make it easy to tell if my switch was properly connected
Old 03-01-2016, 01:51 AM
  #54
Jonesmeister11
OHHHHHH yeah, our center arm rests are different. When spring break comes, I can remove the arm rest to fix my wire situation. I'll take pics. I still haven't really gotten around to getting sideways yet
Old 03-02-2016, 02:48 PM
  #55
Jonesmeister11
Can anyone confirm or deny ABS working? I've been driving around with the module off, and was wondering if in an emergency will the car perform the same?
Old 03-02-2016, 05:45 PM
  #56
Gregor12
Gregor12's Avatar
Go find some gravel or flat grass and slam on your brakes going above 10mph. See if your brake pedal fights you or not. I wouldn't trust someone's opinion on the forum when it comes to safety unless they truly know for sure.
Old 03-03-2016, 11:32 AM
  #57
Lt8Che
'Cuz Racemod-erator
Lt8Che's Avatar
I would test the ABS situation but I think I have a fuel pressure issue or boost leak currently so I'm taking it easy until the build.
Old 03-03-2016, 05:02 PM
  #58
Jonesmeister11
Took a while to find some grass that was flat enough, and not someone's yard haha, but I can confirm that for MY car, ABS is still active.
Lt8Che (03-04-2016)
Old 03-04-2016, 12:25 AM
  #59
Gregor12
Gregor12's Avatar
Lolol nice!!
Old 03-04-2016, 12:35 AM
  #60
Gregor12
Gregor12's Avatar
Damn man that sucks. Got any leads ok what the issue is??
Quick Reply: DIY: Traction Control Switch (Really Shut Off Traction Control)
