The "4 door Z" build (4DRZ)- 13 G37S 6spd sedan
Old 10-07-2015, 05:35 PM
  #61
sLADe781
sLADe781's Avatar
Originally Posted by 4DRZ
You are right, I totally forgot that part. It did seem rather pointless since they already come with their own dust boots for the shock and I am more concerned with the shock than the top hat. What did you do with the stock boot?
I cut up the stock boot and used the upper piece as described per the instructions. I honestly don't know what it does/doesn't do but I just did it since it was in the instructions and was able to get proper clarification from Tein. lol
I just used a tall jack stand to compress the rear spring to bolt it back up. If you tried to do that by hand, I can imagine that would suck. Another thing that helped was I did not bolt up the shock bottom until I secured the bolt for the spring. That allowed the whole hub to pivot to help line things up.
Yeah, strange. I used a floor jack to raise the bucket but I don't know why I had such a hard time aligning everything. I eventually got it in the end but it was a huge pain. Glad you didn't have any issues.
Old 10-08-2015, 02:46 PM
  #62
4DRZ
4DRZ's Avatar
How far down from the top hat does the boot extend? Did you do that in the front too?
Old 10-08-2015, 05:55 PM
  #63
sLADe781
sLADe781's Avatar
I don't remember off the top of my head but I believe it was about .4". The actual length is in the instruction manual and it basically extends just long enough to be flush with the bottom of the top hat. The upper ring fits right in there.
Yep, I did that for both the front and the rear.
Old 10-08-2015, 06:32 PM
  #64
4DRZ
4DRZ's Avatar
Well I guess if I see any corrosion I will just put some waterproof grease up there
Old 10-12-2015, 11:18 AM
  #65
MaQG37
MaQG37's Avatar
Any pics of the drop? Any noises coming from the rears? I just got a set of BC's, may switch to these pending if I can get to my desired ride height.
Old 10-12-2015, 12:05 PM
  #66
4DRZ
4DRZ's Avatar
The rears are quiet. It looks pretty slammed right now on the stock rims/tires with the tall sidewalls, but there is quite a bit of height adjustment. I bolted up one of the winter rim/tires in the front and it looked fine with 2 sizes less sidewall on the same diameter rim. I will post some pics once it starts snowing and I put on all the snow rims/tires.
Old 10-12-2015, 12:09 PM
  #67
Received 4,574 Likes on 3,425 Posts
Same here, and all I have are the rears. These Tein Basis CO's sure seem like a win.
Old 10-12-2015, 12:22 PM
  #68
MaQG37
MaQG37's Avatar
I am thinking of buying them to have a quiet rear end. BC's squeak/clunk + 35 profile tires dosen't make for a very nice ride.
Old 10-14-2015, 01:29 PM
  #69
4DRZ
4DRZ's Avatar
The Tein's are still quiet a week later and plenty of bumpy road testing. I am debating on 18's with 45/40 series tires or 19's with 40/35 series tires. I think I would be ok on either setup with this suspension as it is pretty smooth on just about every type of road
Old 10-15-2015, 02:32 PM
  #70
4DRZ
4DRZ's Avatar
I just posted a review of the Tein Basis coilovers after more driving in the Review Only section with some installation tips
blnewt (10-15-2015)
Old 10-19-2015, 03:31 PM
  #71
4DRZ
4DRZ's Avatar
Recently installed a Redline leather shift boot and Torque Solution delrin shift ****. Here is a link with tips and pics:
https://www.myg37.com/forums/drivetr...lrin-****.html
Old 10-19-2015, 03:49 PM
  #72
Boot looks great, a little over-exposed in the picture, but I suspect it's a perfect match for the perforated components on the black leather seats. Did you remove the shift pattern in the bezel, or is that just an effect of the flash?
I like the color and size of the ball ****, but it looks weird so low like that. Do you know who Commander Strax is?
Maybe a matching boot ring would help? Or if not matching to the ****, what about brushed SS or Ti, to match the trim?
Old 10-19-2015, 04:52 PM
  #73
4DRZ
4DRZ's Avatar
You can blame my phone's wierd auto night mode for the pic. There was no flash so it tried to really brighten everything up to the point of erasing the shift pattern. I thought it was strange too.
Maybe the angle of the pic makes it look exceptionally low, but it looks fine in person. It is definitely lower than the tall stock set up.
Strax? Haha, maybe if it looked more like my thumb.
The leather has since settled a bit so now there is just enough gap between the boot and the shift **** to get my fingers completely around it. Works great!
Old 10-22-2015, 01:39 PM
  #74
4DRZ
4DRZ's Avatar
Here is a better pic without the helmet head now that the leather has softened up a bit. Just a bit of the raw shift lever shaft sticking out, because racecar.
Old 10-28-2015, 10:19 AM
  #75
4DRZ
4DRZ's Avatar
Had to have the Redline armrest cover modified/installed as it did not fit right. Looks good now.
Quick Reply: The "4 door Z" build (4DRZ)- 13 G37S 6spd sedan
