G37 lowering database
Old 06-10-2009, 04:11 PM
Every time a new person contemplates a drop, they have to search the entire forum (although most don't) to get basic information to find out what suits their needs. If those who have a specific setup would be willing to post it here, it can be a great reference thread for those looking to choose a setup or even for those who are already dropped to experiment with wheel and tire sizes, offsets, how low they can go without rubbing, etc. Please post your info if you are dropped whether it's on springs or coilovers. Comments?
  • Coupe or Sedan
  • What suspension are you dropped on?
  • What's your ride height (the measurement from the ground to the highest point of your fender opening in the center)?
  • What are your wheel and tire sizes/offsets?
  • Do you rub?
  • Is your drop even side to side?
'08 Coupe
Suspension: Tanabe Sustec Pro S-0C coilovers
Ride height: 26.0" Front 26.25" Rear
Tire/wheel size: 20"X9.5" +32 245/35/20 Front - 20"x10.5" +34 285/30/20 Rear
Slight rubbing when aligned to factory spec (trimmed fender liner and bracket to completely eliminate it)
Even all around (of course it is, you can adjust coilovers!)
For reference:
G37 Coupe stock ride height (measured from level ground to highest point of fender): Front: 28.15" sport, 28.03" non sport Rear: 27.76" sport, 27.64" non sport
Old 06-10-2009, 04:34 PM
JKashat
JKashat's Avatar
Vehicle: 2009 Coupe
Suspension: KWv3, SPC front & rear camber
Ride Height: 26"
Wheels: VOLK Racing GT30's
Front - 20"x9.5" (+35mm)
Rear - 20"x10.5"(+37mm)
Tires: Pirelli PZero Nero
Front - 255/30/20
Rear - 305/25/20
No rubbing, Period.
EDIT: Installed SPC front camber kit,raised right height from 25.5" to 26", and trimmed the felt inner liner on the rear. No rubbing at all, need to redo alignment.
Old 06-10-2009, 04:39 PM
jarborn1
jarborn1's Avatar
Vehicle: 2008 Coupe
Suspension: Eibach
Ride Height: Not sure
Wheels: Stockies
No rub, not even a little...(and i like a good rub)
Will update when mah wheels get here..
pincheseyha (10-30-2017)
Old 06-11-2009, 11:37 AM
graphiteg37
graphiteg37's Avatar
'08 Coupe
Ride height: Pending...still messing w/ height
Wheel: Advan RZ
Tire/wheel size: 19"x9" +35 245/40/19 Front - 19"x10" +35 275/35/19 Rear
Rub: Nope, none at all
I have my set-up so that you can't see the top of the tires. Want to go lower but I scrape everywhere as it is.
Old 06-11-2009, 11:49 AM
GiGGaplease
GiGGaplease's Avatar
Vehicle: 2008 Coupe
Suspension: Eibach
Ride Height: havent dropped the front yet but the rear...i have like a one finger gap.
Wheels: volk gt-force
20x9.5 +31 toyo t1r 245/35/20
20x10.5 +28 nitto extreme zr 275/30/20
yes, i rub. like on bumps going a fast rate of speed...which is like everywhere. ha
Old 06-11-2009, 12:10 PM
Triple_X
Triple_X's Avatar
* 09 G37x coupe
* Eibach
* 1.5 finger gap in fronts, almost 2 in back
* 20 x 9 +38 255/35/20 (all 4) vredstein ultrac sessentas
* no rub anywhere
* Most of the time front driver is 1/2 inch lower and rear driver is 1/2 inch higher...sometimes all even
Will probably be pre-ordering KSport coils when they officially announce summer release date then going much lower in summer, back to eibach-ish in winter
Old 06-11-2009, 02:33 PM
oOmikeyboy
oOmikeyboy's Avatar
Vehicle: 2008 6MT Coupe
Suspension: Kwv3, SPC Rear camber kit w/ toe bolts, no front kit yet.
Ride Height: just under 26" from apex of fender to ground all 4 corners
Wheels: Volk GT30's, Tires: Toyo T1-R
---Front: 20x9.5 (+35) 245/35/20
---Rear: 20x10.5 (+37) 275/30/20
no rubbing issues. Whats interesting is the KW's on my car are on the lowest setting in the rear, but is still not as low as i'd like to go. My trunk is completely stripped.
Old 06-11-2009, 03:46 PM
xyz
xyz's Avatar
Originally Posted by jarborn1
Vehicle: 2008 Coupe
Suspension: Eibach
Wheels: Stockies
Same as his . . . but i'll update the ride height:
26.5 inches front and rear.
Old 06-11-2009, 03:56 PM
STOOF
STOOF's Avatar
Vehicle: 2008 G35s 6MT
Suspension: JIC Magic Coilovers
Ride Height: Front-25 3/8"; Rear-25 3/4"
Wheels: Ive had a few, but the most aggressive so far until my iforged come in:
20x8.5 +25 245/35/20
20x10 +28 275/30/20
The only rubbing i do is the plastic inside the front well when i hit dips.
Old 06-13-2009, 03:29 PM
chris9012
chris9012's Avatar
Vehicle:08 Coupe
Suspension: Eibach Pro Kit
Wheels:
20x9.5 +? 255/30/20
20x10.5 +39 295/25/20
NO RUBBING i want to go lower actually there is a small gap in the rear and front i want no gap
Old 06-21-2009, 10:40 PM
HamstersG
HamstersG's Avatar
'08 Coupe
Suspension: Eibach, Front and Rear SPC Camber Arms
Camber: -0.5 Front, -0.9 Rear
Ride height: 26 5/8" Front, 26 7/8" Rear
Wheel size: 19" OEM
Spacers: +15mm Front and Rear, #10 Copper Crush Ring
Tire: Yoko s-Drives 245/40 and 275/35
No rub anymore after I trimmed bumper bracket and the wheel lining. The first time I got rid of enough of the bumper bracket, but not enough of the lining. So trimmed some more. Perfect now.
Old 06-22-2009, 08:42 AM
For the losers who measure distance in "fingers":
Please put an actual measurement of your ride height from the ground to the top of the fender opening in inches. "1 finger" or "2 fingers" is a measurement of how far you get on a date with your slutty girlfriend, not a scientifically accepted measurement of distance. Get a tape measure or yard stick please! Thank you.
Amended my setup info int he first post.
The following 2 users liked this post by Black Betty:
G37xsfun (02-24-2016), KellingFrenzy (08-27-2019)
Old 06-22-2009, 09:50 AM
Triple_X
Triple_X's Avatar
LOL!
Old 06-23-2009, 03:19 AM
xyz
xyz's Avatar
Updated w/ new wheels:
Vehicle: 2008 Coupe
Suspension: Eibach Pro-Kit, SPC Rear camber kit w/ toe bolts
Ride Height: 26.5'' front and rear.
Tires: 245/35/20 front and 275/30/20 rear
Hankook Ventus v12 evo
Was rubbing on big bumps . . . until today. Trimmed rear fender and metal piece.
Old 07-08-2009, 10:39 AM
philter25
philter25's Avatar
'09 Coupe
Suspension: eibah prokit
Ride height: 26.75 front, 27.25 rear.
Tire/wheel size: stockies
no rubbing at all....
Drop is pretty even side to side, varies by 1/8-1/4 inch some days depending on weight in the car, fuel, tire pressure, etc.
https://www.myg37.com/forums/members...h-springs.html
Quick Reply: G37 lowering database
