Help LED Signal Replacement
I have a G25x, I just ordered switchback 7444 LED bulbs for my turn signals, I also ordered 2825 LED bulbs for the parking lights, I ordered one set of 6ohm 50 watt load resistors. I know I need to splice into the positive for the turn signal and the and the negative for the turn signal
My, Question is since I'm doing LEDs in both and they share the same negative, is anything else required to make this work? More resistors, or different connections? I just wanna make sure i get it right.
Thanks in advance!
Thanks in advance!
2011 G37 Sedan
In order for the hyper blinking to stop, it's actually the green with black stripe and white with black stripe that you tap into. Hope that helps everyone.
I'd like to add that as a professional aviation mechanic and avionics tech, I would never willingly use scotch locks. If you want a very nice wire install use environmental splices instead.
photocat
09-03-2015 01:46 PM
KZK
Canada
09-02-2015 05:30 AM
