Help BLNEWT and team - Ferrada FR2 fitment question
I have a 2011 G37 journey non-sport sedan
not dropped
I bought the following wheels offsets
what are the fattest tires I can install on these wheels
Front: 20X9 et 25
Rear: 20X10.5 et 38
I want to know the fattest tires I can put on and also if in the future I install big brake kit ..will it fit behind the front wheels
Thanks guys..super stoked to install this new setup
not dropped
Front: 20X9 et 25
Rear: 20X10.5 et 38
Lol, I'm not BLNEWT, but IIRC the widest you can go up front will be 275 and the rear 295 without getting messing with camber and or flat rolling the fronts fenders (not that big of a deal) and pulling the rears (definitely not recommended and may require add'l body work)
for brake clearance those specs shouldn't be an issue, but it really depends on the specific wheels, try the template on here to see if they will clear.
Awesome, thanks for your help - Hashim!!!
Quick Q - Can you please give me the actual recommended tire sizes for both front and back
I was thinking 245 - 35 - 20 and 285 - 30 - 20?
If I go 275 front and 295 back - Can I do 275-35-20 and 295-30-20 or what exactly should I get - Sorry for noob questions lol
Just don't want to mount the tires and then have to return it lol
From my experience, I had a set of 20x10.5 +35 fitted with 275/30R20 in the rears and it was right at the fender with camber. On another set of wheels, my fronts were 19x9 +20 I believe and it had 245s on there. You for me, 255 is probably the widest I could have gone but I am fairly low also. I am sure if I raised my car up I could fit a wider tire.
Latez
Latez
I think Pandas tire sizes are pretty much what I'd recommend, keep in mind not lowered and keeping camber in spec those tires will be poking outside the fenders and may require a bit more camber to safely tuck into the fenders.
Need 4 Speed
Wheel & Tires
59
Feb 23, 2017 08:07 PM
Ruben-Unleashed
Wheel & Tires
Jul 27, 2016 04:53 PM
anyone hello
