AWD tire size help for wide rims
Old Nov 3, 2018 | 01:13 AM
Gabebapes's Avatar
Gabebapes
Ive searched for a few hours and only found one mention on the rim size close to what im getting. i know awd are sensitive so im looking for some knowledge on which tires to purchase. The wheel size is 18.9.5/10.5 +15/22. i was thinking of doing 275/40 18 for the rear and 245/45 18 front. any input is appretiated.
Old Nov 3, 2018 | 11:33 AM
stealthee's Avatar
stealthee
Size wise you can't really get any closer between the two, however the 245's will be stretched on a 9.5" wheel. Most places recommend nothing wider than 8.5" but some say 9 is okay, but from personal experience 9 is pushing the limit on them.
Old Nov 3, 2018 | 04:39 PM
Gabebapes's Avatar
Gabebapes
Ok thanks I'll keep that in mind I just dont know if rear should be 285 or 275 will be fine I dont want that much stretch
Old Nov 5, 2018 | 02:48 PM
Baadnewsburr's Avatar
Baadnewsburr
either will work in general.
I've run 245/285 on my AWD for a few years with no problems but most people run 245 front and 275 rear b/c the OEM rims accmodate those sizes well.
but 245 front and 285 rear is a closer match than 245 front and 275 rear when it comes to AWD as the diameter difference is smaller
Also with wheels that wide you're better off with the 285 rear and wont look as stretched
Old Nov 5, 2018 | 11:20 PM
Gabebapes's Avatar
Gabebapes
I'm going to be installing godspeed springs. You think 285 will have clearance issue and also another question I'm thinking of doing 255/40 on front and 275/40 on rear. Should I go with 45 tire height or stick with 40s.
Old Nov 6, 2018 | 10:24 AM
Baadnewsburr
with enough camber it may be ok, depends on how low the springs go, whether you have a coupe or sedan, whether you are going to install adjustable cambers arms front and rear, also the rims that wide are going to be very close especially the 10.5 in the rear...with that many variables you need to provide more info.. Check out the threads in the suspension forum,
for the tire size, try the tire and wheel calculator in the tools drop down above
Old Nov 6, 2018 | 11:27 AM
Gabebapes's Avatar
Gabebapes
yea I have haven't found the same setup with all the info. It's a sedan and the drop is supposed to be 1.6 all around. No camber kits or mods
Old Nov 10, 2018 | 07:24 PM
slartibartfast's Avatar
slartibartfast
Those are very aggressive offsets for a sedan. Look in Tech/Wheels and Tires forum for more information and more focused assistance.
Old Nov 13, 2018 | 11:11 PM
You won't see that same setup because it won't work on a sedan (with no camber kits or mods that is). you'll need heavy camber or some fender work to get those aggressive offsets to tuck.
Old Nov 14, 2018 | 02:23 PM
Gabebapes's Avatar
Gabebapes
I'm not sure what u guys mean by "it wont work" can u specify the car has springs right now
Old Nov 14, 2018 | 09:08 PM
slartibartfast
The wheels push too far out to fit without steep negative camber or beating the fenders out.
Sahej19
Jan 29, 2019 01:46 AM
main_shoby
May 15, 2015 11:20 PM
reddragonpryde
Oct 2, 2014 11:52 AM
Jimmah
Aug 6, 2013 02:38 PM
dare738
Oct 11, 2010 07:54 PM
