Should I get em?
Old Apr 10, 2018 | 02:43 AM
Romeo1's Avatar
Romeo1
Should I get em?
Hey experts Someone is selling these wheels and tires and I want them and was wondering if they would be the proper size for my G37x sedan 2011?
Set of 4 like new 19” Fast Rims with Yokohama S
drive tires
225/45R19
Only used for 1 summer
Comes with matching black locking lug nuts
19” x 8.5”
5/114.3 bolt pattern
Old Apr 10, 2018 | 04:05 PM
drive tires
225/45R19
19” x 8.5”
Probably fine unless the offset is over 50 or under 25, also be sure the hub bore is at least 66.1mm, and you'll probably want hub adapter rings to keep the wheel hubcentric (assuming the bore is over 66.1mm). Once you find out the hub bore you can usually find the exact hub adapters to fit.
