Help wheels and tires
Old Apr 2, 2018 | 01:51 PM
Cr_08's Avatar
Cr_08
wheels and tires
i have '08 G37s and i just ordered Rohanna wheels Rf2. 19x8.5 front and 19x9.5 back. what would be some good tire size on them?
Old Apr 2, 2018 | 05:44 PM
What offsets did you order, and did you confirm caliper clearance for your bigger sport brakes?
Old Apr 2, 2018 | 08:28 PM
Cr_08's Avatar
Cr_08
yeah. et35 front and et 20 back
Old Apr 2, 2018 | 10:07 PM
Rear wheel edge is going to be about an inch further out in back, so I would consider a 25mm spacer in front to get both wheels similar at the fender edges.
Once you do that I would run a 245/40 front 275/35 rear.
Old Apr 2, 2018 | 11:02 PM
Cr_08's Avatar
Cr_08
What if I run the 225/40 in the front?
Old Apr 2, 2018 | 11:09 PM
slartibartfast's Avatar
slartibartfast
OE 19 uses 225. That said, 245 fits fine and reduces understeer when driving enthusiastically. Or are you just going for stance?
Old Apr 2, 2018 | 11:52 PM
Cr_08's Avatar
Cr_08
Not really going for stance. Just the shop that I went to recommend me to keep the from the same?
Old Apr 3, 2018 | 09:46 AM
225/45/19 should be your OEM, not 225/40, might check what tires you currently have up there.
Also you'll have a different mount going w/ a 225/275 combo, the 225s are a very slight stretch and the 275s are about standard mount, whereas a 245/275 on the 8.5/9.5 stagger would be a both the same sidewall mount. Just a little food for thought
You could run a 225/45 & 255/40 for a more similar mounted setup too!
Chi-City-G
Jul 25, 2016 02:28 PM
canoncleguy
May 4, 2016 10:58 AM
Sython
Sep 12, 2013 10:21 PM
RA080624
Dec 21, 2012 06:43 PM
evilrb
Wheel & Tires
Aug 7, 2009 02:42 PM
