Little help
Old Mar 12, 2018 | 11:04 AM
khan_g37x_'s Avatar
khan_g37x_
Little help
recently bought a set of g37 coupe better known as the 19 spoke but I have a Sedan x here are the specs the guy assured me it would have been a square set up but looking more into it the specs are
19x8
19x 8.5
Fronts 225/45/19
Rears 245/40/19
What can I do to avoid issues or should I sell them
Old Mar 12, 2018 | 01:17 PM
slartibartfast's Avatar
slartibartfast
Lots of people use the coupe 19s on AWD cars.
Old Mar 12, 2018 | 02:50 PM
Are you sure on those specs, or do you have a pic of the wheels? The typical OEM 19 coupe wheels are 19x8.5, 19x9. If you do have those specs I'd keep the 245s and get another pair of them for the front for your AWD, just keep the wider wheels in back.
Old Mar 12, 2018 | 06:14 PM
khan_g37x_'s Avatar
khan_g37x_
So a bit of an update I had properly checked the rims all the rims are stated as the pic below just tire sizes are
Fronts 225/45/19
Rears 245/40/19
Old Mar 12, 2018 | 06:25 PM
the93owner's Avatar
the93owner
If that's the case, and all wheels are the same size (19x8.5 like the picture shows), then just remove one set of tires and put matching tires on them so that they are all the same size. Either 225 or 245 will work.
pahasinfiniti
Mar 25, 2012 04:34 PM
