245 45 20 tires on g37xs sedan?
Old Feb 7, 2018 | 12:09 AM
Adudko1120's Avatar
Adudko1120
Hey guys I recently got a good deal on some wheels and tires and the tires are 245 45 20. I know most people use a 35 sidewall on the tires but wondering if anyone personally has used the 45 sidewall on a 20" wheel and if you had any problems with the all wheel drive system? Thanks in advance!
Old Feb 7, 2018 | 09:10 AM
With AWD going w/ the same size tire all around is best but those 45 series are almost 2" taller and a whopping 7% different vs. oem diameters.
There are those that switch to smaller diameter tires over on the Z sites for tracking and don't report issues, but 7% is quite a bit.
Since you already have the tires you can try them close to home and slowly build up your speed to see if your AWD light comes on, but other than that I surely wouldn't recommend them.
Old Feb 7, 2018 | 02:27 PM
Adudko1120's Avatar
Adudko1120
Oh I see. I guess I'm not going to risk it but just go with the 245 35 20 tire.
Old Feb 7, 2018 | 03:22 PM
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
I usually run 255 35 20 on my 20's. Your speedo will lie to you if you go that much larger. Nothing sucks more than getting pulled over thinking youre doing 10 over, when its actually 14, and get a ticket.
Old Feb 7, 2018 | 05:01 PM
slartibartfast's Avatar
slartibartfast
The AWD models can't go more than 3% larger in diameter than stock. The OE diameter is apparently hard-coded in ECU or TCU.
Old Feb 7, 2018 | 05:08 PM
iCrap's Avatar
iCrap
Well you can go bigger/smaller overall.
The thing is it can't be more than 3% change between front and back. At that point they are rotating at different speeds and that totally confuses they system and can also potentially cause drivetrain damage.
Old Feb 7, 2018 | 05:49 PM
slartibartfast
I understand a 1% difference front to rear.
Old Feb 7, 2018 | 09:16 PM
Yeah, w/ the AWD the 1% diameter variance from front to back when running staggered sets is the line that shouldn't be crossed. There are several cases where the AWD light will come on when going over 80 mph on sets that exceed 1% diameter variance. With RWD that line is commonly drawn at 3%.
There is a gray area as far as how much you can go over/under oem diameter when running a square setup, but again, 7% seems like you'd really be flying too close to the sun
B Feelgood
Sep 1, 2020 02:50 PM
sniper27
May 4, 2011 02:59 AM
Twerkinpnoi
Wheel & Tires
38
Apr 14, 2009 04:41 AM
08g37
Jan 17, 2009 06:44 PM
