TPMS Help
Old Nov 20, 2017 | 09:50 PM
philter25's Avatar
philter25
TPMS Help
Hey guys,
I picked up a set of G35 stock 19s I am going to use as a winter setup. They came with the TPMS sensors (see attached photos).
Will these work with my 2009 G37? Id like to know before I go to the dealership because its way cheaper to buy a set of amazon/ebay than get stuck buying them at the dealership.
Old Nov 21, 2017 | 05:33 AM
Surfnazi's Avatar
Surfnazi
Yes just have discount tire use their tool to reset it
Old Nov 21, 2017 | 09:46 AM
Victory's Avatar
Victory
Given the age of the sensors and the corrosion on the stem, I would assume that one or more of them will be non-functional.
Old Nov 22, 2017 | 12:49 PM
philter25's Avatar
philter25
So I checked with the parts guy at my dealership, and he said it wont work that the antenna on the G37 wont pick up the G35 sensor and I will need different ones.
This response surprised me.
Is there anyone here on the forums running G35 tires with TPMS sensors that had any issue connecting with your G37?
Old Nov 22, 2017 | 12:52 PM
PNW_IPL's Avatar
PNW_IPL
I read somewhere that even g37 from 08-11 use diff sensors and 12+ use different sensors. Given the life span is about 7 years on sensors i would not use them at all.
Old Nov 22, 2017 | 12:55 PM
Victory's Avatar
Victory
They're cheap, just get new ones. Even if they were compatible, the last g35 is 10 years old and with all the corrosion on the stem you'd end up having to replace them before your next tire change.
Old Nov 22, 2017 | 03:45 PM
philter25's Avatar
philter25
The dealership wanted $100 per sensor, so $400 for a set. Yikes! That's almost more than I paid for all 4 wheels!
I ordered a set of G37 sensors online and will use those for the winter set.
Old Nov 22, 2017 | 03:56 PM
Surfnazi's Avatar
Surfnazi
Sensors are generic
Old Nov 22, 2017 | 04:25 PM
stealthee's Avatar
stealthee
Originally Posted by Surfnazi
Sensors are generic
Bingo. You just need to make sure you get the right mghz. What I actually plan on doing with my Lancer is to clone the OEM sensors with the FCC ID number so that when I throw the new wheels on the car won't know the difference, and I don't have to make a trip to the dealer just to reset the TPMS system.
