Tire sizes
Tire sizes
Currently have 225/50/18 on stock rims on a 09 X coupe. Would there be any fitment issues by going to
225/55/18?. They are just over an inch bigger in diameter. Just looking to fill the wheel well a bit more instead of lowering. Will these fit without any rubbing clearance issues?
Thanks for any input
A 225/55/18 will clear but is over 3% taller, may cause other issues, 3% difference in diameter from oem is the line that seems to be drawn as far as where problems w/ ABS & traction control systems may start to occur. There are those, particularly on the Z boards that run smaller diameter tires for tracking that are over 3% without problems but I wouldn't give it the green light.
This would only make a 1/2" difference in the visual gap, not worth the issues it may cause.
As long as all 4 tires are the same size, then you shouldn't have ABS/ Traction control issues.
However I still wouldn't recommend it as it will definitely throw off the accuracy your speedometer. The car will also likely have a softer/ less sharp handling feel.
In addition, I don't think that you will get the look that you trying to accomplish. It will just look like a fatter tire with similar wheel gap. Once you lower it, that should be all you need to minimize wheel gap.
