Help Nail in shoulder, replace one or two tires?
Old Jul 24, 2017 | 03:59 PM
NewEnglandG's Avatar
NewEnglandG
Hey all, got into an unfortunate meeting with a nail in the shoulder of one of my tires on my g37x this morning.
My tread depth on my tires are 6/32nds, is there any potential issue with replacing just the front driver side tire with a new tire at 10/32nds? Or do I need to replace the two front, or all four?
I would assume this different is much less than the tolerance of the AWD system, but wanting to make sure.
Old Jul 24, 2017 | 05:20 PM
JSolo's Avatar
JSolo
Just say no!!!!!
How old are the tires? How many miles?
Personally, I'd replace them at least as a pair for best handling, braking, etc.
Old Jul 24, 2017 | 05:26 PM
NewEnglandG
The tires are less than a year old, purchased the set of 4 on 9/15/2016
Old Jul 24, 2017 | 07:04 PM
NealP's Avatar
NealP
I assume you don't have road hazard coverage? If less than a year it might fine to just replace it with one but I'd measure the treads first to see how much you've worn them out. I've heard if you buy a tire from tirerack you can ask them shave it down to match your existing tires and would likely be cheaper than buying two.
Old Jul 25, 2017 | 12:44 AM
Epiphany's Avatar
Epiphany
If you're down to 6/32nds from 10/32nds, you're probably looking at a four corner replacement. That's a pretty large difference. That or see if you can get a new tire shaved down to match the depth of the others.
Old Jul 28, 2017 | 08:09 PM
Surfnazi's Avatar
Surfnazi
How close is it to the sidewall
