G coupe fitment with verde 370 wheels
Old Jul 12, 2017 | 12:35 PM
Nicks_A_G's Avatar
Nicks_A_G
I have came across a set of verde insignia wheels 20x9 +15 and 20x10 +20 for my 13 g37 coupe journey base. Also just ordered a set of h&r springs, the wheels are recommended for the 13 z base model. It's to my understanding most of the z and g wheels all interchange, what kind of fitment do you think I'll have or any issues with that set up, they should be here tomorrow also curious as to which tires and sizes I need to be shopping for
thanks in advance
Old Jul 12, 2017 | 11:26 PM
Those are pretty aggressive, even for a coupe. If you want to keep your camber close to spec you're going to have to run more of a stretched tire setup.
If it's just the springs that are coming tomorrow I'd look at wheels with a bit more positive offset. For those wheel widths I'd go 10mm more, so a 9 +25/10 +30 would be a set that you could run 245/275 tires without any issues.
If the wheels are already ordered a 245 front 255 or 265 in back, or some added negative camber if you want to run a 275 back there.
Old Jul 12, 2017 | 11:54 PM
Nicks_A_G's Avatar
Nicks_A_G
Ya only thing I haven't bought yet is the tires, so stretch the rubber and she'll look pretty mean, that's exactly what I was hoping you would say haha, thanks for the input
Old Jul 12, 2017 | 11:58 PM
You'll also need new tapered/conical seat lug nuts and best to get hub adapter rings too, need to find the bore size for the Axis wheels, then adapt them to the 66.1mm Infiniti hub. Many aftermarket wheels are 73.1mm. And get aluminum ones, the plastic ones don't hold up very well. Here's one example~
https://www.ebay.com/i/262813537553?chn=ps&dispItem=1
Old Jul 13, 2017 | 01:18 PM
Nicks_A_G's Avatar
Nicks_A_G
yeah it came with rings, would you run 30 series front and rear? What's a good tire that'll hold up for around $200 a piece range, I drive it pretty hard
