Plasti Dip rims?
Old Jun 30, 2017 | 11:21 PM
G37doc's Avatar
G37doc
Plasti Dip rims?
So planning to plasti dip my rims until I can afford a new set of wheels. I'm planning to take the wheels off to spray them so I get even coats and it looks good (using black and the glossifier). Has anyone done so before? Do I just tape off the TPMS sensor? Any and all recommendations/help is greatly appreciated. Thanks!
Old Jun 30, 2017 | 11:56 PM
hurleyguys's Avatar
hurleyguys
i have done it on my friends civic rims. i took the rims off the car and washed it really well with a degreaser. then index card the tires. then just a few even coats. if you get over spray on the tires it rubs off really easily.
Old Jul 1, 2017 | 01:17 AM
Yellafella's Avatar
Yellafella
I think dipyourcar.com has a coating that you can put over your tire's sidewall so if you do get plastidip on the tires, it peels right off after you're done.
Old Jul 1, 2017 | 08:27 AM
G37doc's Avatar
G37doc
Ok cool. Anyone know about using the plasti dip over the TPMS sensor? Should I just cover it with tape? And is it easier to take off 2 rims at a time or all 4? My cousin said he tried doing all 4 at once and said it was rough using the jack stands.
Old Jul 1, 2017 | 09:53 AM
coupecruisin's Avatar
coupecruisin
I used index cards around the rim to protect the side wall while spraying and that worked out good. After 6 months of hating the plasti dip look, I took the rims off and sent them out for powdercoat, so so much better now.
GL
Old Jul 1, 2017 | 10:35 AM
MaQG37's Avatar
MaQG37
If you were going for a high gloss look, the plastidip + glossifier won't get you there.
Try these two products.
https://www.dipyourcar.com/collectio...oflex-aerosols
Autodip - The World' First Sprayable Vinyl Wrap
Old Jul 2, 2017 | 09:07 AM
G37doc's Avatar
G37doc
Thanks for that, I ended up using the plasti dip because I had already bought it but will likely try the autodip in the future since I didn't get a real gloss finish (like you said would happen). Still looks good though! Before
After
Old Aug 2, 2017 | 10:20 AM
itshere's Avatar
itshere
After
Did one bottle of Plasti Dip cover all 4 rims? how is it? any thoughts now that you had it for a while? Thinking of doing the same.
Old Aug 2, 2017 | 11:30 AM
G37doc's Avatar
G37doc
I used 3 cans for a total of 5 coats. Note: do NOT use the index card method seen posted by some people. The plasti dip won't get the outer lip of the rim. I realized this partway through and took the notecards off and just sprayed around now there's leftover on the tire that really won't come off. I tried using tire cleaner a few days after applying and still couldn't. It started to peel off quickly for me, but that might be from the way I applied it.
I ended up just getting the rims (and brake calipers) powder coated and it came out great.
