Wheels and tires question
Old Jun 26, 2017 | 08:52 PM
G37doc's Avatar
G37doc
Hey guys,
New to the forum here. Just bought a 2012 G37x coupe and loving it already. I want to trade out the stock 18" rims for these:
Set of 4 Wheels 19 inch Black Machined Rims 19x8.5 fits INFINITI G37 COUPE | eBay
Was wondering if I got them would I have to alter suspension or just get a set of tires along with them? If so, what size? Can't wait to start making this car look even better and be even faster. Thanks for any advice anyone can offer!
Old Jun 26, 2017 | 09:41 PM
Welcome to the site!
Those wheels won't require any modifications, run a 245/40/19 tire and you'll want these hub adapters, this will snug the oversized bore to the smaller Infiniti hub flange, and these aluminum ones hold up much better than plastic ones.
4 pcs OD : 73.1MM ID : 66.1MM Silver Wheel Aluminum Hub Centric Rings | eBay
Old Jun 26, 2017 | 10:03 PM
G37doc's Avatar
G37doc
Thanks! Good to know. Any chance anyone has ever heard of BMS wheels before? They look great in the pictures but can't find much more info. about the wheels anywhere to determine the quality.
Old Jun 26, 2017 | 11:34 PM
To be honest, a new set of wheels for $600 is going to be a compromise. They will probably be heavy, may have a finish that won't hold up well, might be hard to balance, and might be dangerous (since many cheaper wheels don't undergo thorough testing for strength & longevity). Here's a good link for some wheel standards.
https://www.jwtc.jp/open/html/e/situmon1.html
Many of us (myself included) have bought cheaper wheels but end up buying a higher quality set as time goes on. The difference in weight, strength, and quality of finish is pretty dramatic most of the time. There are good used options that pop up in our classifieds often, so if you have patience something that's much higher quality may show up, for not a lot more than that $600 set. Stock coupe 19s are a nice quality wheel that can be found for about $700 give or take.
Check our wheel galleries for other ideas, and if you still want to try those $600 wheels at least you'll have looked around to see what's available.
https://www.myg37.com/forums/wheels-411/
Old Jun 27, 2017 | 09:58 AM
G37doc's Avatar
G37doc
Ah ok, good to know. Thanks for the all the help and great info!
