19" tire size
Old Apr 10, 2017 | 01:39 AM
allen88909's Avatar
allen88909
19" tire size
2011 sedan sport package
I'm getting from OEM 18" to 19"
OEM
225 50 18x7.5 +45 (front)
to
255 40 19x9 +47
245 45 18x8.5 +50 (rear)
to
275 35 19x10 +30
I have checked, the front will be ok, but my problems is rear. is 275 too wide?
what do you guys run with 19x9 and 19x10 rims?
thanks,
Old Apr 10, 2017 | 05:47 AM
Surfnazi's Avatar
Surfnazi
245/35/19 and 275/30/19
Old Apr 10, 2017 | 06:33 PM
Strokelessone's Avatar
Strokelessone
I run 275/35-19 all around
Old Apr 10, 2017 | 08:31 PM
OEM
to
255 40 19x9 +47
to
275 35 19x10 +30
thanks,
19x9 +47 is pretty conservative and you may not have enough clearance at the calipers since your sport pkg has the big Akebonos. I'd recommend running a 15mm spacer there, this will give you proper clearance at the brakes and you can still run that 255 tire, so your new wheel spec in front would be a 19x9 +32 which is perfect flush fit on a 255 tire.
19x10 +30 is real aggressive for a sedan, you rwheel will be poking outside the fender edge (when looking straight down) about 15mm, or just over a half inch. If you're ok w/ that poke I'd run no more than a 265/40 in back, or run a 275/40 but plan to run a bit extra negative camber (probably about -2.2 give or take.
