Wedsport TC105N questions for my sedan
Old Mar 23, 2017 | 09:18 AM
ryanwhite74115's Avatar
ryanwhite74115
WedSport TC105N and questions related
I drive a 7-speed (autoslush) G37 Sport (Malbec Black). 2013. I hate the OEM duckfeet. I mean I really don't like them. Not only do they not look good, they are extremely heavy for being 18x7.5 and 18x8.5 at ~25-27lbs each. I have found these wheels, seen below, that aesthetically, I like. I like 10-spoke wheels and I think they flow with our body style.
WedsSport TC105N
And the specs on weight are incredible:
https://nebula.wsimg.com/4d9fa715dd9...&alloworigin=1
17-19lbs for 18x8.5 and 18x9.5
So a reduction of 8-10lbs per wheel and they look better. Here's the problem/question for me.
Center bore hub for our cars are 66.1mm last I checked and these wheels use a 73mm hub. Well I know I can buy the conversion hub rings:
4PC ALUMINUM HUB CENTRIC RINGS 66.1MM CAR HUB TO 73MM WHEEL BORE FOR NISSAN | eBay
But, here's the kicker. According to Wed's website, if I use hubcentric rings, I cannot use a centercap.
WedsSport TC105N Center Cap | Footwork Autosport
And according to their website the above is the ONLY centercap that is usable with the above rim. So it seems Wedsport either places people in a catch 22 of center caps and wobbly wheels or no centercaps (and therefore exposed hubs to the elements) and non-wobbly wheels. Am I missing something? If not, can someone, anyone, recommend an alternative rim with similar looks, price and ballpark (20lb or less) weights?
Old Mar 23, 2017 | 09:37 AM
ryanwhite74115
WedsSport TC105N
Old Mar 23, 2017 | 10:43 AM
Pretty sure the staggered duckfeet are 24/25 lbs respectively front to rear... not 25/27.
That certainly sucks about the center-cap and hub design problem.
Here, have you ever seen this link? Might be of some interest.
Wheel weight comparison - Weights of various popular 18-20 inch rims
In fact, the Wedsports you're targeting are in that round-up.
Old Mar 23, 2017 | 11:18 AM
r2dmax's Avatar
r2dmax
I do NOT recommend wobbly wheels. Not sure how it works with Japanese cars but I would assume the same. I had a wheel that wasn't hubcentric on my Mercedes and there was a constant vibration (similar to unbalanced tire) and then at certain speeds it felt like the front end would rattle loose. Needless to say I got rid of them pretty quick.
There are a lot of choices that are light weight, similarly styled and hubcentric for these cars
Old Mar 23, 2017 | 11:36 AM
ryanwhite74115
Examples are requested as I have searched and feel like I'm losing it.
Old Mar 23, 2017 | 12:12 PM
r2dmax's Avatar
r2dmax
I just noticed you were doing 18s, but I think BLNewt has these Wedsport SA10R. May want to touch base with him
Old Mar 23, 2017 | 01:21 PM
Maelstrom's Avatar
Maelstrom
find out the hole size and make your own center caps. I know that's not ideal for a nice set of wheels, but it's amazing how limited the options are.
Old Mar 23, 2017 | 02:35 PM
I have the Wedssport SA10R 18x9.5 +38 on my sedan and I use the hub adapter rings and the centercaps that come w/ the SA10Rs without any issues whatsoever. Might contact Jason or Josh at Getyourwheels.com and see what they have to say. If those are indeed a problem w/ that particular wheel on the Infiniti hub might look at the wheels I have or the SA15, SA72, or the newest SA54R. Mine are about 20 lbs, have a very nice finish and nice concavity, FWIW I would buy them again in a heartbeat
Old Mar 23, 2017 | 04:43 PM
ryanwhite74115
Jason at GetYourWheels told me this is a known "problem" with this wheel, but it's not really a problem as they are lug-centric. Does that really work on our cars...we're rolling around in 3800lb chunks of metal...not a miata.
Old Mar 23, 2017 | 04:49 PM
bPChaos's Avatar
bPChaos
I've run around without hub rings for a bit without problems. You have to get the wheels nearly to torque spec while they're off the ground, using those tapered lug nuts that you're supposed to use so that they square up.
I wouldn't recommend it though, but I had to in a pinch while they were on order(apparently Enkei uses a 72.8mm hub... it's dumb).
Old Mar 23, 2017 | 05:56 PM
GetYourWheels's Avatar
GetYourWheels
Thanks for calling in!
As my own personal experience.. I've broken so many of those plastic hub rings on my past cars that I sort of stopped using them. My previous car was a 2015 Lexus GS350 and used no hub rings with steel tapered lug nuts to tighten down my wheels. No issues throughout my commutes. My other previous car being a Acura TL and same thing with various 3pc wheels with cast centers.
- Josh
Old Mar 23, 2017 | 09:38 PM
If you're set on that style wheel have you considered the SSR GTV02? Should be about 21 lbs and is a quality Japan product
