Aspect Ratio Question
I have a '10 G37S and I have to get new tires very soon. Is it a big problem to change the aspect ratio or is it just a visual change? I hate how my car doesn't have the same all around. I also want the front tire a little bit bigger. I want to put 235/45 up front and keep the rear at 245/45. No problems here?
The tires aren't the same size because your OEM wheels have a 1" stagger... 7.5" front, 8.5" rear. It's that difference which makes the 225/50 tires properly matched with the 245/45 tires, respectively.
I'm only putting that out there on the chance you didn't know. I once has a conversation with an Infiniti Service Manager who didn't believe me. That was awkward.
You could run 235/45 front since you have a RWD, the 7.5" is about the narrowest wheel for that tire size, it will be about a 1/2" taller than your 225/50 though.
Like Rochester mentioned, you have 1" wider wheels in back. When you take off your wheels you'll notice there's an extra bolt in front that is there to keep from accidentally swapping your rear wheels to your front.
(IIRC it's in front, could be in back though
)Last edited by blnewt; Feb 8, 2017 at 04:33 PM.
No, you should be fine
The tire profile won't be the same, as you go wider you have to go down in sidewall series to keep the diameters similar. The 235 is a between size vs. the OEM 225/50 & 245/45, if they made a 235/47.5 then you'd have the same profile but the 235/45 will be about a 1/2" taller than your current 225/50s and about a 3/8" shorter than your 245/45s
)You remove the bolt and take off the plastic sleeve than reinsert the bolt into the threaded hole and screw it in with a impact. It backs the rotor off the hub for easy removal.
Maybe it serves multiple purposes lol
Several websites have calculators for comparing different tire sizes, such as:
http://www.discounttire.com/en/learn...ize-calculator
This may help you select and match tires that will suit your particular needs.
