Enkei RPF1 18" on Sedan
Hey all! I wanted another car as my FX35 was becoming a bit impractical to daily drive and I have plans for that car and my R35 to go all out. So I decided to buy a black "daily" 2011 G37s Sedan. I have wheels that I had on my 350z DE and they are Enkei RPF1s 18x9.5 +38 and 18x10 +38. I'm going to get them powdercoated RAYS bronze or go PVD black chrome on them. I haven't picked up the car yet so I cannot do any measurements, but will these fit and clear the Akebono on a sedan? I used one of the 9.5 +38 as a spare on my FX which has Akebonos and it barely cleared... Not sure of tire sizes yet, maybe you guys can give me some recommendations. They currently have 265/35 and 285/30 NT05s mounted on them, but will need replacing anyways. The car is stock height as well. Thanks and I can't wait to drive my G!
You were rockin NT05s on an FX?? Those tires are way too low profile vs. the OEM diameter, should clear your Akebonos and I'd run 255/45 front 275/40 rear, you might get some poke at stock height but should tuck ok under compression.
Nope. The wheels came off of my 350z but I had to run one on my FX as the stock spare didn't fit over the Akebonos when I had a flat. It sits on 22s. thinking of running 255/45 with a 285/40 looks like its the same diameter. You think I would have to roll fenders in the rear if I do a mild drop on coils?
Should be ok in front, I'm running 18x9.5+38 all around on 245/45 and have room to spare. 255s in front should be ok, in back I think a 275/40 would be an easier fit, 285s with that offset on a 10 at stock height will poke a fair amount and may contact the fender under compression.
