Help oem 19" fitment
Old Nov 25, 2016 | 09:01 PM
z 2 g's Avatar
z 2 g
oem 19" fitment
Has anyone used the factory sport 19x9 wheel on the front(13 G37 CPE rwd), or know if there is any issue doing so. Clear bbk, rubbing with 245/40 tire, etc.?
Old Nov 25, 2016 | 09:12 PM
There's no issue running those in front, there is a little bolt screwed in the hub that keeps the front & back wheels in the staggered setup from being switched, if you have a Sport pkg then you'd just need to remove that bolt. And they will clear the BBK and have conservative offsets so no rubbing problems there.
Old Nov 25, 2016 | 10:27 PM
z 2 g's Avatar
z 2 g
Thanks, have just been reading in the stickies, guess this should of been there. I've found a good deal on four OEM rear 19's. I'm already on the 245/275 tires with the staggered wheels. Have the small brakes currently but looking to upgrade in the near future. Just wanted to make sure the 19x9s with the tire set up will work. Great heads up on the hub bolt also.
