Can I fit 18 x 10.5 at +12 square set up on a 2012s coupe?
Old Oct 11, 2016 | 09:24 PM
awestrella14's Avatar
awestrella14
Need help with this fast or I may loose a really good deal on wheels. Is this possible and efficient. I am performance focused 100%. Any help is appreciated!
Old Oct 11, 2016 | 09:42 PM
Here's a link to those on just the back of this coupe, IMO it would take some work to get them to fit without issues unless you really want to stretch the tires. Infiniti G37 custom wheels Rays GramLights 57DR 18x9.5, ET +12, tire size 255/40 R18. 18x10.5 ET+22 275/35 R18
Old Oct 12, 2016 | 08:54 AM
VenomGT9's Avatar
VenomGT9
Possible? Yes
Efficient? Probably not but doable.
The rear won't be much of the issue, just get a roll and about -2deg of camber with a 275/40
The front will take some work and camber tweaking to fit even with a decently stretched tire.
Old Oct 12, 2016 | 09:05 AM
Ryne's Avatar
Ryne
The Steering Wheel Guy
If I'm reading everything correct, the proposed wheels will be 10mm more aggressive than the picture you linked Brad. Correct?
Old Oct 12, 2016 | 04:17 PM
Ouch, thanks Ryne, you are correct, the backs are +22, not +12, thanks! SO even worse OP
Old Oct 14, 2016 | 11:48 AM
That Dude's Avatar
That Dude
Hope it isn't too late but you can fit them with the right sized tire, you would need a 255/35 or 245/35 and a little camber in the rear. I'm running a similar setup, just 2" bigger in diameter.
You don't need to roll anything in the back, there is nothing to roll, and with that diameter you might not even need to do anything with the bumper tab. The front would benefit from a roll but you can go without it, natural rolling will fix it in a week of driving. Good luck.
ClassyPump
Oct 27, 2016 10:42 AM
renn90
Oct 12, 2016 06:27 PM
Swift-Hartz
Oct 8, 2016 03:28 PM
Juscus
Oct 4, 2016 10:37 PM
