Any DIY mods to get OEM Infiniti center cap to fit in aftermarket wheels?
Old Sep 23, 2016 | 10:50 PM
Melophile's Avatar
Melophile
I want to paint my OEM Infiniti center caps and use them in my aftermarket wheels. Has anyone else done a mod like this?
Old Sep 24, 2016 | 12:09 AM
It would be extremely unlikely you'd be able to use them, most aftermarket wheels use larger caps. What you can do is go to a site that sells center cap decals that you can apply to your aftermarket caps. That's about the best you can hope for unfortunately. Something like this~ http://www.ebay.com/itm/like/141938017234?lpid=82&chn=ps&ul_noapp=true
Old Sep 24, 2016 | 12:22 AM
iCrap's Avatar
iCrap
yeah, that's sort of what I did. I have a vinyl cutter so i just made it on photoshop, exported and cut it.
Old Sep 24, 2016 | 06:22 AM
Melophile's Avatar
Melophile
The center caps that came with my XXR wheels are essentially a blank cap with an XXR sticker. I measured my OEM Infiniti center caps and it's almost the exact same size as the XXR sticker. The only problem is that there are clips on the OEM Infiniti caps.
Using whatever means necessary to remove these clips (sand, file, cut, etc), I then assume that'll allow me to pull out that old bottle of super glue and put it to work. It's sound rather simple, I think I might try it. I definitely would like to keep the OEM Infiniti center caps on my aftermarket wheels; you simply just can't compare the OEM center caps to sticker of the Infiniti logo. All I need is something that'll match my OEM Infiniti center caps to the color of my wheel. I was thinking some regular-'ol plasti dip should do it, but I just hope the difference in the types of coats won't be too noticeable.
Old Sep 24, 2016 | 08:56 AM
Well, if you can get those OEM caps to fit, then I'd just paint them w/ some Duplicolor w/ adhesion promoter, should look much better than plastidip. G/L****BTW, nice job on those caps iCrap, looks almost factory.
Old Sep 24, 2016 | 06:02 PM
MaQG37's Avatar
MaQG37
I used duplicolor over the weekend, they came out great. Just be sure you are spraying in low humidity.
Old Sep 24, 2016 | 06:43 PM
Very nice job there, what Duplicolor paint color/# is that?
Old Sep 24, 2016 | 08:39 PM
MaQG37's Avatar
MaQG37
It's their graphite with their clear coat. $4.99 a can
Old Sep 24, 2016 | 10:00 PM
Melophile's Avatar
Melophile
Low humidity you say? Pretty rare to find some of that in Florida 😂
Ryne
Jan 19, 2017 02:25 PM
saywat?
Nov 14, 2016 02:37 PM
avol3xo
Nov 10, 2016 10:45 AM
JG_G37
Sep 27, 2016 09:42 PM
main_shoby
Sep 21, 2016 09:14 PM
