Low Tire Pressure but No Warning Light
Old Sep 11, 2016 | 12:38 PM
ctng37's Avatar
ctng37
The title speaks for itself. I noticed that my left rear tire was at 25 psi (when it should be at 33 psi) but my warning light did not go off. Does anyone know what's wrong, if anything? This is on the stock 18" wheels for the sport package sedans if that helps.
UPDATE:
The sensor is fine. I released it to 20 psi and before I was able to shift it in to reverse, the warning came on. Thank you guys again for your help and suggestions!
Old Sep 11, 2016 | 01:35 PM
If your car is still under warranty the dealer should be able to replace the sensor(s), that's probably what it is. If it's out of warranty take it to a tire shop, they will have the equipment to take care of it.
Old Sep 11, 2016 | 01:48 PM
ctng37's Avatar
ctng37
Oh Okay. I thought there would be a warning light if there's a sensor malfunction. Which warranty would the sensor fall under? My car has 49k miles.
Old Sep 11, 2016 | 03:42 PM
To be honest I'm not sure if a bad sensor would keep the TPMS light off during a low pressure issue, but would seem to be a sensor problem if it's not relaying that info to the ECU.
Like I said, if you still have warranty left I'd take it to the dealer (after you fill your tire, lol)
Old Sep 11, 2016 | 03:50 PM
ctng37's Avatar
ctng37
Yeah. I'll go get them checked out. Thanks for the help!
Old Sep 12, 2016 | 02:00 AM
crookncastle's Avatar
crookncastle
an 8psi difference in tire pressure probably will not set off the malfunction light on the dash. i would check if you have a puncture in the tire before taking it in to the dealer. if you really want to check if the light works when the tire pressure is low i would release the air down to 10 psi and drive it around the block.
Old Sep 12, 2016 | 08:22 AM
Maybe it depends on the year, but in my 09 under 30 psi would set off the light???
Old Sep 12, 2016 | 01:54 PM
It may take a larger deficit to trigger the warning light. I don't know if I've seen anything authoritative that tells you exactly when the indicator will be triggered. I've heard 25% low. I've heard 10 PSI low.
From personal experience I've not had it come on unless the tire was very low. I've checked pressure and found it as low as 26 or 27 with no indicator triggered.
If the TPMS is damaged I think it's supposed to illuminate and flash for a minute or two when the car is first started. I think.
Old Sep 12, 2016 | 05:23 PM
ctng37's Avatar
ctng37
There's a leak somewhere. I might try that out to see if the sensor is fine, crookncastle. I thought the warning would flash if there was a malfunction too. There's probably nothing wrong with it, might just be due to it not being in the range for the warning like you guys said.
crazieight
Aug 30, 2016 02:50 PM
S73G
Aug 30, 2016 10:24 AM
JohnnyD
Intake and Exhaust
Aug 28, 2016 12:50 PM
Mattyem
Aug 26, 2016 11:42 AM
brevi
Aug 23, 2016 09:35 PM
