View Poll Results: Staggered set-up g37s.. how many miles do tires last?
10,000~20,000
7.14%
20,000~30,000
64.29%
30,000~40,000
21.43%
45,000~50,000
7.14%
50,000~55,000
0%
Voters: 14. You may not vote on this poll
Old Aug 2, 2016 | 09:12 AM
G37X GraSdadow's Avatar
G37X GraSdadow
Staggered wheels with same tire sizes. No Tire Rotations..
How many miles do your tires last on your car?
Old Aug 2, 2016 | 01:03 PM
slartibartfast's Avatar
slartibartfast
Why would they wear any different than when mounted on same-size wheels?
It's alignment and driving style that impact tire wear. I'm pleased to get more than twenty thousand miles out of a set of tires.
Old Aug 2, 2016 | 03:06 PM
G37X GraSdadow
because if they are staggered wheel set up(even 0.5 difference) I won't be able to do any tire rotations. (Most performance tires are asymmetrical)
If I have squared set, I could just swap fronts with backs
Old Aug 2, 2016 | 03:22 PM
The tire itself makes more of a difference than not rotating or a mild neg camber. High performance, summer-only (aka, Three Season) tires typically last 15K miles, give or take a few thousand. Rears wear out a little quicker. All that assuming normal, spirited, daily driving. (slartibartfast drives like an old coot, whereas I'm also old, but drive like an idiot. )
When's the last time you heard your tires scream while you swept into a turn, or launched the car hard without traction control? If the answer is "this morning", then figure 10-15k miles on a set of performance tires.
It's the compromise you have to make if you want to play. Just is. Don't sweat it, man.
Old Aug 2, 2016 | 04:12 PM
G37X GraSdadow
I am planning to get either michelin pilot A/S plus or Continental DWS06 245/40/19 all around for my Xsedan with staggered wheel set up(Coupe sport wheels).
I was told that for AWD, its never good to have staggered set up.
However from this forum, lots of people have upgraded their wheels to coupe wheels and its proved to have zero issues.
My concern is that for G37x, its almost like RWD(20% front 80% rear something like that), rear will wear out quicker.
I was also told that for AWD, its better to swap all tires when the rear ones are weared out. Which will be very costy.
Perhaps I was wrong, I'm just trying to see what would be the best in long term.
I have a person who is willing to trade my rear(9.0) for his front(8.5) in local but in worse condition. (Mine is 9/10 and his is about 6,7/10).
Old Aug 2, 2016 | 04:20 PM
If you do run staggered try one of the combos in this list that are a positive %, this means the rear tires are slightly larger, this will work better over time since the variance will get closer to equal over time.
18s
235/45 & 265/40 (0.07%)
245/45 & 275/40 -0.07%
255/45 & 285/40 -0.22%
19s
235/40 & 265/35 -0.37%
235/40 & 275/35 0.67%
245/40 & 275/35 -0.52%
245/40 & 28535 0.51%
20s
235/35 & 275/30 0.07%
245/35 & 285/30 -0.07%
you should expect over 20k miles easily on All Season tires, and like mentioned above, w/ proper alignment the staggered set should get within a couple thousand miles of a square set. Not being able to do a full rotation will hurt a bit but not enough to be a deal breaker.
Old Aug 2, 2016 | 04:22 PM
Those 19" Sport Coupe rims are only a 1/2" stagger. You're right about the anecdotal evidence here... it won't mean a thing to your AWD car.
However, if I had an AWD G, I'd take that opportunity you're describing to get same-sized wheels, then rotate those puppies every 5k miles to keep an even tread.
And if you're putting A/S tires on that car, you can expect much better lifetime out of the the tread. Figure 20K give or take.
Old Aug 2, 2016 | 04:30 PM
G37X GraSdadow
Thank you guys! I appreciate it!
Old Aug 2, 2016 | 04:56 PM
JSolo's Avatar
JSolo
Just say no!!!!!
I must be driving too slow. I've never heard the tires squeal or scream in corners. I do corner fairly aggressively, but apparently not enough. The street is not the place to be exploring limits.
If I didn't replace the stock with pss earlier this year, I'd say they could of gotten a good 25-30K+ on the fronts and ~23-24K on the rears. This is the stock re050a tire. I also swap out winter tires for about 4-5 months of the year.
I do rotate on the same axle every 6K miles. I expect similar or better mileage from the pss's. It's worth noting usual acceleration is slower than most but to a faster cruising speeds. Braking is gentle too. Try to read the road and avoid complete stops.
Old Aug 2, 2016 | 05:35 PM
You've got performance tires and a sport suspension. And where you live doesn't give you much opportunity to experiment, which you're not inclined to do anyway. Besides, aggressive is a subjective thing that can only exist with a modicum of stupidity.
I had those same tires when I bought the car. The rears lasted barely more than 10K miles, and the fronts just under 15K.
Old Aug 2, 2016 | 07:12 PM
slartibartfast
Invoked DSC today while going to Discount Tires. Drop throttle oversteer averted, darn it.
Old Aug 2, 2016 | 09:37 PM
JSolo's Avatar
JSolo
Just say no!!!!!
@Rochester, it's all grid out here. I get no pleasure from straight line speed. No point in needless tire/fuel waste. Need to drive at least 150 miles to get to any real roads.
Old Aug 2, 2016 | 10:50 PM
Based on what you and I are saying, perhaps the single most significant factor in tire mileage is driving behavior. And while I'm no hooligan, perhaps I am too hard on the car.
Old Aug 3, 2016 | 01:21 AM
slartibartfast
Not too hard. Harder than most.
Old Aug 3, 2016 | 03:28 PM
Lego_Maniac's Avatar
Lego_Maniac
I've been consistently getting 10-12,000 miles out of my tires. OEM 050A, the S04s, then PSS, then another set of PSS.
Pretty hard to get PSS to squeal, even when pushing hard.
