Picking a wheel that fits
Old Jul 29, 2015 | 09:02 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
SO im running 20x9 Vossen now but im thinking of going back to 18's but know nothing about Rims.
here is what im looking at running
SSR GTV-01 what would be a better setup
18x9.5 +22 or 18x9.5 +35
im lowered on Eibachs is that helps..
throw in your thoughts about what size tires would work with the setups as well.
thanks
Chuckie
Old Jul 29, 2015 | 10:27 PM
thanks
Chuckie
Chuckie,
I'd go with 18x9.5 +45 running 245/45/18s all around
Here's Carls sedan on those exact specs w/ SSR GTV03s
If you don't mind a bit of poke in front the +35s would work, the +22s are too aggressive with in spec camber and no fender mods.
The Toyo Proxes T1 Sports are a nice summer tire for good pricing too!
Then added a mild Tanabe drop
https://www.myg37.com/forums/build-t...ourney-11.html
Old Jul 30, 2015 | 11:14 AM
chuckie311's Avatar
chuckie311
Awesome those look good!! Thanks for you're help
Old Mar 11, 2016 | 01:22 PM
chuckie311's Avatar
chuckie311
so i decided to go with SSR 18x9 +35 offset pretty sure these tires should fit with no issues..
would like to go with 265/40/18
anyone see any issues with running a little wider tire..
right now im running a 20x9 +38 vossen with 255/35/20
Old Mar 11, 2016 | 02:02 PM
VenomGT9's Avatar
VenomGT9
Why the drop all the way to 18s?
19s will fit the wheel well better
Old Mar 11, 2016 | 03:09 PM
chuckie311's Avatar
chuckie311
want more of a tire with the 4.08 gears i cant give the car more than half throttle without the tires spinning..
i'm not getting rid of the 20's ill still use them..
there will be no issue with the wheel well.. my car is pretty low with 0 gap
Old Mar 11, 2016 | 11:43 PM
You meant the 18x9.5 +35, they don't make a 9 AFAIK, that will be a nice flush fit.
Old Mar 12, 2016 | 12:33 AM
chuckie311's Avatar
chuckie311
no ill be running a 18x9 +35 SSR GTV01
from my invoice
SSR GTV01 Wheel Matte Black 18x9.0 5x114.3 35mm
Old Mar 12, 2016 | 02:00 AM
Strokelessone's Avatar
Strokelessone
I am definitely interested in how they look when you get them. I was looking at the GTV02's in the same size.
Old Mar 12, 2016 | 02:19 AM
da mayor's Avatar
da mayor
Just get a better tire too for maximum grip
Old Mar 12, 2016 | 08:32 AM
from my invoice
Lol, sorry, I was looking at treadepots' listing and they list a
GTV01 18-9 5:114.3 35ET SILVER
and a
GTV01 18-9.5 5:114.3 35ET SILVER
Just glossed over the 9 & 9.5 difference as they look too similar when speed browsing
They should be a nice setup and those 5 spokes will look
Chuck, you may have to flat roll the front fender edge, it's a simple job, under hard compression those 265s may rub if you keep the fender edge as-is.
What tires are you considering?
Old Mar 12, 2016 | 05:54 PM
chuckie311's Avatar
chuckie311
I was looking at those as well was a tough decision to decide between the two
Old Mar 12, 2016 | 05:58 PM
chuckie311's Avatar
chuckie311
and a
Yeah I was afraid of that i think I'm going to go with 255/40/18
Think I'm going with the continental extremecontact dw
Old Mar 12, 2016 | 06:05 PM
chuckie311's Avatar
chuckie311
Here is where I compare all my tires I compared the 265 to my 255/35/20 I'm running now they are a tad wider but smaller diameter
https://tiresize.com/comparison/
Old Mar 12, 2016 | 06:49 PM
chuckie311's Avatar
chuckie311
Not that easy when you run a 35 series tire
