Best looking size tires and performance on g37 sedan
I am doing some research in buying new tires for my g37. I currently have 225/50/18. what do yall suggest for a little bit wider tire and a closed gap between the wheel well
Welcome to the site BTW. And any future wheel threads check this folder~
https://www.myg37.com/forums/wheels-and-tires-307/
On a RWD you'll be OK, I wouldn't recommend it for an AWD though.
If you have the RWD S pkg you should have staggered wheels, the fronts should be 7.5" wide and the rears 8.5", fronts should run a 225/50/18 and the rears should be 245/45/18. I'd check your rims to be sure, they should have a stamp on the inside or just take a tape measure across the width of the wheel (they won't be 7.5/8.5 because that's at the bead) but the rears will be an inch wider. If you have all four 7.5s or all 8.5s you can run the 245/50s, just a bit more sidewall roll on the 7.5s.
BLnewt- what if keeping the car staggered? I have similar situation 11 sport (at) sedan but will probably keep staggered set up...what would be the upgrade, but still within oem specs...?
Thanks
Thanks
drewfinity
Aug 20, 2015 08:17 PM
