G37X square setup offset?
I'm going to be getting Wheels soon and wanted to know what offset to go with on a square setup for my G. I have searched for the last hour or two and really only came up with results for staggered setups.
Not looking for anything too aggressive so I will be going with 19x8.5 all around with 245/40/19 rubber, the wheels im going with are Ace Convex and are offered in 35, 38, 40, and 45mm offsets. which should i go with to have the best fitment? car is dropped on swift springs.
I'm seeing quite a few AWD cars running staggered setups. wondering if i decided to go with a staggered setup what tire sizes would be ok and not mess with the AWD system. still trying to make since of offsets and tire sizes in relation to the AWD sedan.
18"
235/45/18~265/40/18 (0.07% variance)
245/45/18~275/40/18 (0.07%)
255/45/18~285/40/18 (-0.22%)
19"
235/40/19~275/35/19 (0.67%)
245/40/19~275/35/19 (-0.52%)
245/40/19~285/35/19 (0.51%)
20"
235/35/20~275/30/20 (0.07%)
245/35/20~285/30/20 (-0.07)
255/35/20~295/30/20 (-0.22%)
The variance w/ a minus means the rear tires are smaller than the front, it's best to have a bigger rear tire diameter because they wear faster, this will bring variance closer to zero over time.
Looking at these Ace Alloy Convex Matte Titanium 19x8.5 19x10 Staggered Wheels
19x8.5 front 245/40/19 offsets 35,38,40,45
19x10 rear 285/35/19 offsets 40,45
I have also been playing with the tire/rim calculator and i can only get a + variance in the front by going with a 255 tire up front, can that be done without rubbing?
If you don't lower your G go w/ +40 in front.
Good fit and AWD variance is as good as you can get w/ 19s.
redlinernyc
Feb 29, 2016 11:06 PM
