TPMS problens :(
Old Nov 15, 2014 | 03:46 PM
Carfanatic's Avatar
Carfanatic
Exclamation TPMS problens :(
Well let me try to explain my issue :
Put on winter tires and 2nd set of TPMS sensors
Turn on car , tire light flashes for a few min then goes solid,
I tried the re-learn but that didn't effect anything
Still at square one
Should I take it too Infiniti and just have them program it
The relearn method I touch the paper clip to metal but regardless my light is always flashing
Any tips or advise would be appreciated
09 G37x Coupe
Old Nov 15, 2014 | 04:28 PM
quakerroatmeal's Avatar
quakerroatmeal
I would go to discount tire and have them use the wand/program tool they use to reprogram each tpms. The relearn method is too finicky..you have to be exact on timing.
Old Nov 15, 2014 | 04:59 PM
Carfanatic's Avatar
Carfanatic
Thanks man your right it's not worth the hassle , isn't there a
Reset tool we could buy for home use like the OBD readers we have ?
Old Nov 15, 2014 | 05:15 PM
Black_G37S's Avatar
Black_G37S
1) Make sure your paper clip making a good contact with the wire inside the connector socket!
2) Tapping the paper clip to any ground post 6 times right away after you push the push-start button to KOEO
3) Following exactly what the instructions in the DIY say
If you do the above steps right then you should not have any problem.
Old Nov 17, 2014 | 09:14 AM
Carfanatic's Avatar
Carfanatic
Fine... Is you say so i'll give it another try , over the weekend , this time instead of using a paper clip i'll use a wire and i'll tape it to the white thing that way im positive its making contact and the i'll touch it to a piece of metal 6 times within 10 seconds .
Hopefully works
04G35NYC
Dec 24, 2015 01:00 AM
Depravity
Oct 16, 2015 01:37 PM
jgronline
Sep 21, 2015 08:44 PM
JG_G37
Sep 19, 2015 09:07 PM
Thirty_Seven
Sep 18, 2015 11:34 PM
