Convertible wheels on all four corners?
I've learned through this forum that the convertible sport rear wheels have a more aggressive fitment than coupe sport wheels. My question is: does anyone happen to know if it is possible to run those wheels on all four corners without rubbing or fender rolling? It would also be a plus if that setup could be used while keeping the alignment in spec.
The main reason why I ask is because I want to ditch my 20mm all around drm spacers which seem to cause minor vibrations at above 75mph. I know aftermarket wheels are probably the easiest solution towards optimal fitment but I prefer the look of the coupe 19s or the 2013 370z rays.
Any input is appreciated. Thanks guys!
https://www.myg37.com/forums/brakes-...ml#post3816507
KZK
Canada
Sep 2, 2015 05:30 AM
