8.5 vs 9.0 for squared set up
Have an AWD sedan and want a nice square set of 19" Coupe Rims.
As I'll have to basically make the set from scratch.
Any feedback going with 19x8.5 on all four corners?
Would 19x9.0 be the preferred setup?
* found a cheap local set and the seller says they are curbed might not be totally straight.
Is there an "acceptable" tolerance for bent rims?
Is it usually visually obvious if they are not straight?
Thanks In advance for your input
Here's a site if you need one or two
Infiniti G37 Wheels Rims OEM Alloy Steel Wheel Rim
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
