19x9 oem wheels mounted up and lessons learned
Give them a call. I highly doubt it. What they have will be 8.5 inch 43mm offset most likely..
I called four different dealers(two direct) and two aftermarket infinit sites who are tied into the inventory and can see who has what or not. I got the last set, unless there is one not in the system which seems unlikely.
Nice find, be sure to post some shots when you get them on
It wasn't the deal everyone else got, but still better than most aftermarket set ups and it was what I wanted, so still worth it!!
Love how it looks. There is nice contrast with my body color vs. the sublte hints of gunmetal in the wheels. Looks so nice.
Android pics don't do it justice.
For those who want to know who orderinfinitiparts.com is... It is Infiniti of Charlotte. When my order from them came I checked the ship from address and matched it up with the dealership address. They are the same.
Also, I must be the only one that doesn't think the math of the difference between the front and rears isn't a big deal. When u add the extra quarter inch to each side of the wheel and subtract it from the 13mm offset difference, it's impossible to tell from a side view picture unless the owner says what they are.
At any rate, both setups look nice and without a drop the 8.5 +43 is the
safe choice. With a drop the 9 +30 has a nice flush fit.
Actually it's a pretty big difference, you've got the 6mm for the 1/2" wider rim and another 13mm further out w/ offset for a net 19mm, about 4/5ths of an inch, pretty significant IMO.
