Tire suggestions
Old Mar 18, 2014 | 12:23 PM
Morgs's Avatar
Morgs
Tire suggestions
Im looking for some summer tires for my x sedan, im goona be running coupe wheels with 245/40/19 tires.
Ive been looking on tire rack and am interested in the sumitomo htrziii, kuhmo ecsta spt, bfgoodrich sport comp 2 or the bridgestone potenza s04 pole position. Im a bit more concerned about tread life and noise as opposed to all out performance... any thoughts on these?
Old Mar 18, 2014 | 12:41 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
The only one I've heard of would be the potenza pole positions. I have them now and I'm quite happy. The lifetime could be significantly improved by rotating the tires on a squared setup. The performance is excellent also.
Old Mar 18, 2014 | 01:47 PM
rks's Avatar
rks
The bfgoodrich sport comp 2 have great tread-life and are highly rated. That's what I would go with from your list.
G37xsDriver's Avatar
G37xsDriver
Just put a set of Goodyear Eagle F1's on The Red 2009 G37xS...so far very impressed very quiet ride is outstanding....we'll see
Old Mar 18, 2014 | 01:49 PM
G37xsDriver
Highly Rated at TireRack as well
Old Mar 18, 2014 | 02:18 PM
I'd give a look at Toyo T1Sports too, here's a link
Proxes T1 Sport Tires by Toyo - Buy Proxes T1 Sport Online | Tread Depot
Ask for Andrew and mention myG37.com for best deals.
Old Mar 18, 2014 | 08:53 PM
Lego_Maniac's Avatar
Lego_Maniac
I have S04 pole positions. I like them so far, but I don't expect to get much more than a year (12,000 miles for me) out of them.
Next time I'll get Michelin PSS.
Old Mar 19, 2014 | 11:39 AM
nissanlvr's Avatar
nissanlvr
I don't have a Sport model so can't offer you specific testimony, but I usually stick with either Michelin or Bridgestone for tires... I think they consistently make better quality tires than most other brands.
I have Kumho something tires on my car now, and wouldn't recommend them. They're a little loud and too stiff for my taste. If you're on a budget, they aren't horrible, but if you can pay a little more I'd go with another brand.
Out of what you listed, I'd probably go with either the Bridgestone or BF Goodrich (BF Goodrich is Michelin's value brand, like Firestone is to Bridgestone).
Go on tirerack.com and look at ratings and reviews for all the tires you're considering. That website has lots of info. Survey ratings are broken down into lots of categories, so you can see how people have ranked each tire for noise and tread life, since those are important to you.
Old Mar 19, 2014 | 02:23 PM
connoisseurr's Avatar
connoisseurr
I've personally used all the tires you mentioned above with the exception of the Potenza (which I know is an incredible tire). Sumitomo HTRIII is a great tire. I was deciding between those or Firehawk Wide Ovals and I went with Firehawks because of it being all-season and they perform great on my neighbor's RS4.
Stay away from Kumho Ecsta - I've had two sets replaced under warranty, 6/8 tires had bubbles within 5,000 miles.
G-Force Sport Comp 2 is a great summer tire and performs well in dry conditions. I had slipping issues in wet conditions. Also, the sport comps are a noticeably louder tire.
If those are your only options, I'd go with the Sumitomo. Otherwise check out the Toyo T1Sports as Brad mentioned. One of my favorite tires, hands down.
Old Mar 19, 2014 | 02:58 PM
t0nym4c's Avatar
t0nym4c
Hi,
I recently replaced the good years that came with my car with Falken 453 and I have to say they're a huge improvement. They stick to the ground much better than the good years and they are also not as noisy, but they are by no means a quiet tire. For the price they are great.
Since I just got them I'm not sure how long the tread will last.
Old Mar 19, 2014 | 04:54 PM
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
Almost a week ago I had Yokohama S.drives put on my G. I also have the coupe 19s. I have been very happy with them. They are a very sticky tire but quiet at the same time. The only time they become a little noisy is when you're hitting the brakes hard or when you're taking a turn pretty hard. My brother has them on his Audi TT and took me out on some back roads this past weekend and gave his car hell taking turns much faster than I could imagine possible and had no problem keeping traction at all. The tire tread is very aggressive. I had a little bit of snow the day I had them installed and it did about as good as the all seasons I had on the car throughout winter, although I wouldn't suggest running them in the winter. I went with 225/45/19 in the fronts and 245/40/19 in the rears and probably could have done 245/45/19 front and 265/40/19 in the rears, or similar. If you'd like I can post a picture of the tread and how they sit on the coupe 19's.
Old Mar 19, 2014 | 07:04 PM
itzricky's Avatar
itzricky
Just got Conti ExtremeContact DWS, they ride like a boss.
Old Mar 19, 2014 | 10:13 PM
AUR11's Avatar
AUR11
I love the so4 and just got the 245/40/19 all around for 180 a tire. I used to run the continental dw extreme and it's a fantastic tire but just a little soft on the sidewall. I put around 19k miles on them on my Lexus and they still had plenty of life left. They are 198 per tire right now. Very quiet too.
Old Mar 20, 2014 | 06:35 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
Mix of classes here. The B-Stone would offer the best in dry handling and steering response hands down. The Sumi would be a close second of that bunch from the max perf summer class. Those Comp 2's are my top pick in the next class down. More wear and better ride, still plenty of handling to play with on the street for dd use. Kumho brings up the rear.
For what your describing, I'd run the BFG.
Old Mar 24, 2014 | 06:31 PM
Morgs's Avatar
Morgs
awesome, thanks Neal, i ordered the comp2's and a set of sway bars
ZachThomas
Sep 3, 2015 01:40 PM
