Question about 5mm spacers...lip or no lip?
Old Mar 7, 2014 | 10:48 AM
Dr.Pat's Avatar
Dr.Pat
I just received a set of H&R 5mm spacers that were supposed to be hubcentric. The problem is that they have a beveled edge instead of a lip. I thought hubcentric spacers are supposed to have a lip that the wheel sits on so it doesn't vibrate? I have hubcentric rings on now, but I don't think that the wheel will be able to catch on the ring once the spacer is on.
Thoughts? Did I receive the wrong ones? I have Concept One RS-10 wheels (20x8.5 and 20x 10) if that matters...
Here's a pic...
Old Aug 17, 2014 | 03:54 PM
JC-RH's Avatar
JC-RH
I have a similar situation, but with 8mm spacers.
Do you know if yours have a center bore of 66.1? Did you ever install them? We're they snug and allowed your hubcentric ring to sit on top?
Old Aug 17, 2014 | 06:09 PM
I believe 10mm spacers are the thinnest available hubcentric spacer
Old Aug 21, 2014 | 05:54 PM
rhdh104's Avatar
rhdh104
What's a good 5MM Brand.... G37x Coupe Stock S wheels.
Old Aug 21, 2014 | 07:31 PM
H&R is the most well known, Ichiba is also a decent choice, both should come w/ longer studs AFAIK.
charneco
Feb 21, 2016 11:11 PM
drewfinity
Sep 24, 2015 11:01 AM
ay37
Sep 15, 2015 08:51 AM
bingpwr
Sep 4, 2015 09:44 PM
