10,5
Hey bro's. I'm preparing to purchase vossen cv5 10,5 around /20' w/ eibach springs. Is it good decision ? Do i need any spacers? Will be any scraps? And what tires would u propose me. Thinkin about vredestein ultrac 285/25/20 245/30/20. Thanks buds!
You shouldn't need spacers as long as your offset is correct. I would pm Diego@vossen and he'll let you know what he recommends, I believe the best choice in tires would be 245 in the front and 275 in the back.
I run 245/35/20 in the front and 285/30/20 (lionharts) in the rear with coilovers just fine. I had eibachs on about 2 months ago, but I decided I wanted to go lower as there was still about 1 1/2 finger wheel gap in the rear.
It's all about the wheel offsets. There are offset calculators online which shows how much more/less a different sized wheel will be from the fender.
Just measure the distance between the tire to the edge of the fender and that's the most amount of space you have to work with. If you want to go nice and flush, a fender roll will probably be necessary.
As far as tires, 245/35/20 F and 275/30/20 R would probably be best. 25 is pretty darn skinny.
