Help 10.5 square
Old Jan 9, 2014 | 03:32 PM
jesse550's Avatar
jesse550
10.5 square
So I'm going 10.5 +25 all around and thinking about going 255/35/20 all around but I'm worried about potholes and what not in the NYC area. Is there a safer tire setup I can run without rubbing? Currently dropped on eibachs.
Also what brand tires run wider if that helps? Or handle stretch the best
Old Jan 9, 2014 | 03:36 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
It would help if you also posted what wheel diameter you plan on running with those.
Old Jan 9, 2014 | 03:41 PM
pebkac's Avatar
pebkac
I imagine he wants to go with 20s....
Old Jan 9, 2014 | 03:47 PM
jesse550's Avatar
jesse550
Going with 20s lol
Old Jan 9, 2014 | 04:32 PM
Jesse, VA 55 lists a few tires in this thread that handle stretch setups pretty well. I've had the Toyo Extensa and they're OK, not as grippy as my Toyo Proxes4 plus but OK.
https://www.myg37.com/forums/3720711-post11.html
BTW, IMO the 255s are about the widest tires you can run up front w/out rubbing all the time, so that 255 probably would be best, here's Natalies' 10.5 square on a Sedan for reference w/ 255s
https://www.myg37.com/forums/picture...g37-sedan.html
Old Jan 9, 2014 | 05:39 PM
jesse550's Avatar
jesse550
thank you very much, I guess I'm sticking with my original plan. Only thing I still cant decide is which brand tire to get and which would visually look like the least amount of stretch
Old Feb 1, 2014 | 05:40 PM
DonVito's Avatar
DonVito
did you ever get around to putting these wheels on? pictures perhaps? cuz im looking to do a square set up on my 2012 G37S 6MT 20x10 +35 offset and want to get a semi aggressive look but not too crazy. wondering how it will work out
Old Feb 14, 2014 | 12:50 PM
jesse550's Avatar
jesse550
yeah, pics added here:
https://www.myg37.com/forums/g37-cou...ml#post3738236
Italia311
Jun 28, 2016 11:25 PM
Depravity
Oct 16, 2015 01:37 PM
helloandchau
Oct 6, 2015 05:26 PM
pal51961
Sep 27, 2015 08:38 PM
