Need Help with my G37X 20 "
Old Nov 28, 2013 | 02:26 PM
Carfanatic's Avatar
Carfanatic
Question Need Help with my G37X 20 "
Hi Everyone,
Well i've been reading and reading through posts but in the end i feel like there is barely any information on G37X coupe in terms of tire pkg.
I've decided to go 20x9 and 10.5 staggered setup
However since its a "x" im so lost in terms of having safe tires ..
Im trying to avoid buying a camber kit "i think thats how its spelled"
my idea is go 245/35/20 in the front and go 285/30/20 in the rear and according to what i've heard my differential will be less then or equal to 1% which is necessary for the G37x otherwise i can burn my transmission...
BTW : for winter's i went 245/45/18 all around x-ice 3
Thank You
Old Nov 28, 2013 | 06:37 PM
Originally Posted by Carfanatic
Hi Everyone,
Thank You
I'm assuming you're planning on lowering your G, if so you will probably want a camber kit just to keep everything safely in spec and to keep your tires from premature wear. If you're only changing the wheels/tires but keeping your suspension stock there's no need for any camber help.
The tires you listed are perfect for a staggered X, you can't get any better.
Everything you listed should be fine depending on your wheel offset, that is the one critical piece of info missing. Something in the mid +20s to low +30s should be fine.
Old Nov 28, 2013 | 10:29 PM
Carfanatic's Avatar
Carfanatic
Smile Should offset be a big concern
The mags I'm buying have Offsets are 32f and 42r
There used mags and were on a g37s
I think I should be okey my tire combination is fine and I don't have sports breaks
Let me know what you guys think
Thanks for the reply
Old Nov 28, 2013 | 11:18 PM
Those offsets are a bit on the conservative side for a coupe but will work alright, you might want spacers to bring the wheels out a bit, but those offsets are better than ones that are too aggressive.
sChiG37xS
B4 'n Afta
Nov 6, 2016 06:14 PM
ArmyBoyd
Sep 22, 2015 08:54 AM
dsolis
Sep 17, 2015 11:25 PM
pro-gadgeter
Sep 17, 2015 07:37 PM
IrishMike
Sep 16, 2015 07:07 PM
