who has 20x11 on there sedan?
I wanted to know if anybody had 20x11's on there sedan. If so what off set are they and please post pics if you can. Thanx...
*i want to run with K3 projekt, rohana wheels rc22 or vossen cv5 20x10f, 20x11r. I will be lowered on tein s tech springs*
I'm running 20x10 +45 w 295/30/20 tires on my rear and it's flush w/ -1.2 camber dropped about the same as STechs on coils. You'd probably have to be in the +50 offset range unless you go out of spec w/ your camber or run a bit stretched w/ your tires. For the fronts on 10" rims offset about +45 should do it.
Here you go...
20x10 +31 and 20x11 +41 255/35 and 285/30 tires with camber within spec in front but a little rubbing and -4.1 camber in the rear.
I had 235/35 and 255/35 tires on there and was fine with normal camber but didn't want to run that much stretch so I changed it up.
I would have replied sooner but school is killing me.
thank you for the help. I end up going with a 20X10 all round. The shop that im getting the wheels from order a few sets so ill be trying +27 all around and or +40 all around. I will post pics as the wheels come in.
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
johnadlertech
Sep 14, 2015 12:22 PM
johnadlertech
Sep 14, 2015 12:18 PM
