Tire offset help
Old Feb 2, 2013 | 10:29 AM
  #31
tmmueller's Avatar
tmmueller
just run a touch of rear camber. Stock is -1 or -1.5 degrees isn't it? With the camber kit maybe you are literally running no negative camber.
Old Feb 4, 2013 | 12:35 PM
  #32
nanotech's Avatar
nanotech
Thanks for the help. I guess ill try to return both the front and rear tires and get 265 and 235. Or at worst just keep the 245 for the front and exchange to get the 265 for the rear.
Old Feb 4, 2013 | 01:21 PM
  #33
Diego@Vossen's Avatar
Diego@Vossen
Biggest issue are the rears, Falken FK452 or Toyo T1r sits nice out back but other brand 275s like Nitto/Hankook sit very aggressive and you will need more negative camber to make it work which we do not recommend. 265s are a great option but a rare tire size and only a few brands make them and are very expensive. 255/30/20 will be stretching a bit, but it is actually not to bad as long as you go with a thick tire like Nitto NT555 which almost don't looked stretched at all.
Old Feb 4, 2013 | 01:29 PM
  #34
Diego@Vossen
Here are +25s with 275/30/20 Falken tires. No rear camber kit just H-Tech Drop.
Old Feb 4, 2013 | 01:31 PM
  #35
Diego@Vossen
Hope this helps, if you need to chat, call me at our office.
Old Feb 4, 2013 | 01:36 PM
  #36
Diego@Vossen
Here are my old 265/30s.
265/30/20s
Camber within specs also ^^^
+25 again with 255/30/20s.
Old Feb 4, 2013 | 02:25 PM
  #37
nanotech's Avatar
nanotech
Thanks Diego!! This really helps!! I also checked the official vossen thread for ideas and I will continue to look around for ideas. I really wanted to go with Nitto because of my Front tire being Nitto. Once again, thanks a bunch.
Old Feb 4, 2013 | 03:21 PM
  #38
GTLAW's Avatar
GTLAW
OMG!!!!!!!!!!!!!
So much bad info being given in this post!!!!
Your offsets for the CV3 are fine 20-F 25-R Your tires are what is the problem! You are running a 285MM wide tire on 25MM offset. That is too too wide for our cars.
Just change out your tires I recommend PSS in a Front 240.35.20 -- Rear 275.30.20
This will keep your speed-O within OEM specs.
Stock Tire - 225/45R19 Search Tires Tire 1 - 245/35R20 Search Tires
Section Width: 8.85 in 225 mm
Section Width: 9.64 in 245 mm
Rim Diameter: 19 in 482.6 mm
Rim Diameter: 20 in 508 mm
Rim Width Range: 7 - 8.5 in
Rim Width Range: 8 - 9.5 in
Overall Diameter: 26.97 in 685.03 mm
Overall Diameter: 26.75 in 679.45 mm
Sidewall Height: 3.98 in 101.09 mm
Sidewall Height: 3.37 in 85.598 mm
Radius: 13.48 in 342.39 mm
Radius: 13.37 in 339.59 mm
Circumference: 84.72 in 2151.8 mm
Circumference: 84.03 in 2134.3 mm
Revs per Mile: 771.2
Revs per Mile: 777.5
Actual Speed: 60 mph 100 km/h
Speedometer1: 60.4 mph 100. km/h
Speedometer Difference: - Speedometer Difference: 0.816% too fast
Old Feb 4, 2013 | 07:32 PM
  #39
nanotech's Avatar
nanotech
From what I've heard and seen a 275 won't work with no negative camber. I think 265 would be a better fit.
Old Feb 5, 2013 | 02:01 AM
  #40
Ahmad_1290's Avatar
Ahmad_1290
I've got the same wheels but with 275's. I had to shave down the bumper bracket for it to stop rubbing.
Old Feb 5, 2013 | 10:02 AM
  #41
nanotech's Avatar
nanotech
Well I have trimmed all I could of the bracket and I just want to solve this issue for good. I am planning to just get the 265 and be stress free.
Old Feb 5, 2013 | 11:11 AM
  #42
BosMaSwaG37's Avatar
BosMaSwaG37
I would NOT reccommend 275 on a +25. Not only is it to big but it'll look f-ing ugly! I owed the CV3's with the same offsets. 265/30 were prefect for it. If you want to rock wider tires, get higher offsets, FACT! on my Front +20 offset I went with 235/35. If I did it again, I would do 235/30. My boy had it and it looked better and of course no rub. You can't have the best of both worlds. High offsets = option for wider tires and low offsets = no choice but moderate to extreme stretch.
Old Feb 5, 2013 | 02:09 PM
  #43
nanotech's Avatar
nanotech
Ya I am just going to go with the 265/30. All I need to do is go to Discount tire and hopefully they will give me most of the credit back for the 285/30 I have.
Old Feb 5, 2013 | 04:35 PM
  #44
nanotech's Avatar
nanotech
Discount tire is just giving me $50 per tire!!!!! I've barely even used them!!
Old Feb 5, 2013 | 06:47 PM
  #45
Yep, once a tire is considered used they'll screw you big time. Might try selling them in the marketplace here. Don't just give them away to those guys
