Oem Infiniti rims on a sedan
Old Sep 9, 2012 | 02:44 PM
drizzy315's Avatar
drizzy315
Guys Sorry to be a pain but im one thise ppl need understand and make sure on everything before i regret it later...anyways ok found a good deal of used ones on ebay now im past the fact that width rims difference is ok that is what makes them staggered now this pair rims im looking at comes with some good tires but sizes are slighty off and i understand whole diameter should be same but wouldent that always be same diameter is 19' rims the obviously tire diamter will be 19 as well... Now im little confuse about the Threadwidth and the profile does that also have match all around ? Because the tires are talkimg about are 225/45r-19 front and 245/40r-19 rear...will this work ? Take a look link below :
http://item.mobileweb.ebay.com/viewi...821&cmd=VIDESC
Promise guys this is my last question i really appreciated!!!
Old Sep 9, 2012 | 03:51 PM
Here's the factory tire sizes for 19" coupe staggered and 18" Sedan staggered
Sizes To Fit Your Vehicle
Old Sep 9, 2012 | 04:01 PM
drizzy315's Avatar
drizzy315
Ok well im putting 225/45-19 front 245/40-19 in rear which are factory specs
For coupe on my sedan i should be good to go right? Jus a simple yes or no? Apreciated very mich believe me
Old Sep 9, 2012 | 04:30 PM
Yes, perfect fit, your diameter difference is minimal (0.97%)
Old Sep 9, 2012 | 04:41 PM
drizzy315's Avatar
drizzy315
Hey bl you are the man appreciate it check this out would appreciate your feedback on this
Old Sep 9, 2012 | 05:57 PM
Look nice, too bad they're sold, here's some other that you might consider
FS: G37 OEM 19" wheels and tires - G35Driver
FS: G37S Wheels - G35Driver
You might also check this thread, some members on there have replied that they have sets for sale so you might try contacting them
https://www.myg37.com/forums/private...s-w-tires.html
Old Sep 9, 2012 | 09:41 PM
drizzy315's Avatar
drizzy315
Hey bl again man many thanks your a life saver you taught me this in matter few hrs take in mind i didnt know a thing about all this stuff...i send pm on those post you send me hopefully get a response soon the pair selling for 1500 with hankooks tires look really good...thank s again bro!
Old Sep 9, 2012 | 09:45 PM
bat6wc's Avatar
bat6wc
Originally Posted by LexiG37
Alright, this is getting painful. Chill out and do some research.
Read up on tires and wheels a bit. Check out an online tire size calculator.
+1
if you are afraid of running staggered, just do what i did....BUY 2 SETS OF FRONTS OR TWO SETS OF REARS!!
Old Sep 10, 2012 | 01:41 AM
drizzy315's Avatar
drizzy315
Hey Bl this tires are different from last pair
I showed u and i think i might be pushin it with that3% difference between tires what do you say? They are 245/35-19 all around
http://m.g35driver.com/forums/showthread.php?t=414519
Old Sep 10, 2012 | 08:57 AM
Those 35 profile tires will affect your speedo quite a bit and yes, they're over 3% change from stock so I think I'd get new tires if you like those wheels. Not sure if the 3% change from stock will affect any other systems such as the VDC or ABS. I DO KNOW that having front & rear differences of greater than 3% will cause problems w/ your AWD, but not sure going w/ all 4 tires the same but over 3% from stock will cause other problems other than big speedo
differences.
Keep in mind that if you consider 20" wheels your tires will be cheaper, just food for thought, and there's a lot of wheels out there that look as nice or nicer than the oem rims, just sayin......
Old Sep 10, 2012 | 11:50 AM
drizzy315's Avatar
drizzy315
Right that is exactly what i was thinking they are 3% different from stock but not from each other...so not sure if that 3% difference applies in this case ...i thought that you factor that in if the tires in fron where on size and ones in back another...what is speedo? I really like the wheela especially becaue there are painted gunmetal alredy.
Old Sep 10, 2012 | 02:03 PM
Speedo~Speedometer, when you're going 60mph w/ those larger diameter tires it'll show that you're only going 57mph, (but you'll be putting less miles on the car, lol)
Old Sep 10, 2012 | 04:07 PM
drizzy315's Avatar
drizzy315
I think i should be ok... Tirea all same size
Old Sep 11, 2012 | 01:07 PM
  #29
maxximase's Avatar
maxximase
Been awhile since I've asked, so I'll try again. Can't seem to find anyone who has done this, which is surprising, unless there is a fitment issue.
Has anyone put the 19" Coupe REARS on all 4 corners of a RWD S Sedan? I would like to get away from the staggered setup so I can rotate my tires.
Old Sep 11, 2012 | 07:45 PM
  #30
sniper27's Avatar
sniper27
Yes, it has been done.
